Question about Neovo AG E-17A 17'' LCD Monitor
The sceen is black but wen u press the power
The sceen is black but when u press the power botten off then on a again u can see a flash of the picture but it dose not stay on can u tell me how to fix it
Posted on Jun 14, 2010
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
  • Bud Martin
    Bud Martin Jun 15, 2010
    Sef53, Please open it up and inspect the inside as I describe what to look for inside the set. Send me pictures if you can, budmrtn@aol.com
Flashes 6 to 7 times
mine has done the exact same thing, and apparently ( have yet to try) there's a second fuse in the tv and that's the problem, now I need to locate the fuse!!! lol mines an older Philips, let me know if yours is the same problem
Sep 06, 2013 | Panasonic TC-P50G15 50 in. Plasma HDTV
Stefieanne, The long, thin, "cold-cathode-fluorescent-lamps" are not staying lit anymore. Unit's "switch-mode-power-supply/CCFL inverter supply will need REFURBISHMENT to restore proper operation. SOFTWARE WON"T HELP YOU!!!!! Visit all links you find while doing some reading in my fixya profile to help you in the big decision you will need to make on what you will do with this "black" or "blank n black" screen ccfl back-lit lcd monitor. Do you have soldering pencil of about 35 watts and some solder and pliers and screwdrivers and even a digital voltmeter. Contract out the work $35 to $90 Tell us what your intentions are. 12fixlouie
Mar 21, 2010 | Neovo AG E-17A 17'' LCD Monitor
I have a gateway notebook,wen i loged it off 4rm the switch frequently. i did this consectively .the forth time it failed to display information on the screen.wen i put it on a mornitor it...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 11, 2009 | Gateway MX3215 Notebook
I HAVE AN ASPIRE 3680. IT WONT START WINDOWS
first connect it to the power then press the power botten continusly till it is shutdown. After that press the power botten again to start it then press F8 key. go to boot with last known good configaretion. if this doesn't work then you definite ly requir the os cd to repair the os.
Sep 21, 2009 | Acer Aspire 3680 Laptop
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
My computer goes to black screen with flashing cursor in upper left corner. does this mean i need to reformat my harddrive and reinstall windows? i didn't install anything new i just rebooted the computer...
Wen yu power up press F2 or F1 or 'del' key to enter in bios check your harddisk is detected in bios.
Open cpu cover and refix RAM memory and reconect power cable and sata or ide cable to harddisk again.
then ceck.
Jul 27, 2009 | Computers & Internet
Digital camera says picture error
it probably says that when the camera has been dropped many times
Dec 11, 2007 | Optimus DC-5347 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Neovo AG E-17A 17'' LCD Monitor Logo
177 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
