Question about IBM NetVista PC Desktop
I have netvista 6578rbg, it can boot from the hard disk
I can boot from my hard disk
    President:
  • 2,351 Answers
Hi lyonson, I gather at one time the drive did function with Vista? IBM has some fix on their web site. Click this link below.
http://www.ibm.com/search/?v=14&en=utf&lang=en&cc=us&hpp=10&catx=Y1zkzPzk6z93z46zP7&q=netvista+6578rbg&cp=&lv=c&cat=k6&x=12&y=10
Even if one of these fix's does not match your exact model no# . Try one that is close. If it does not help call IBM. I assure you it is not your PC but Vista. (There has been & will continue to be more down time with MS's Vista than any other previous version of windows to date). If non of IBM's files listed help you, please call IBM from this link. http://www-304.ibm.com/jct03004c/support/operations/us/en/contracts?cm_re=masthead-_-myibm-_-cs-contracts
I wish I could help more but other suggestions involve erasing the drive & that's not a good idea if you have data on it.
I would appreciate it if IBM solves this issue or one of the firmware’s fix your issue & you post the results. I’d call IBM my self if I had all needed information written on the NetVista PC.
Good Luck!
Mike
Posted on Mar 30, 2008
I bought this cheap computer and made a set of 6 floppy boot disc's. I screwed up somehow later and made the display all ****-eyed. What I want to do is use these 6 boot discks to re-formatt my hard drive...
i really dont think so but good news is you can get dual core 2 gb of ram 320 gb hard drive computers on ebay for 100 pounds anyhow to get back to your problem you can if you want just reistall windows and that might help just get a freinds or yourown disk and boot from disk hope this helps
Mar 12, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
My computer has a virus, I lost my restore disc. The software to restore the system is on the hard drive. When I boot the system, it sticks in a loop at the user log in. I have the win32.netsky virus.
Hia,
try to boot your computer in safe mode. when computer starts, press F11/F12 key to get this option otherwise you can find this from computer manual or from internet as per your model/brand of PC. also you can try to boot computer only on command promt option, might be this way it will allow you to go on to your hard drive C and then you can copy your restore disk files by dos commands to external hard drive or CD/DVD. also you can copy your data before you wiped out everything and restore system.
if nothing works then get ultimate boot cd from internet, burn on empty disk and boot computer from there. this will definatley lets you in and you can copy all data and restore disk. make sure, you setup boot order as boot from CD and computer will boot from CD directly.
let me know if you stuck soemwhere or any issues.
Thanks.
Apurva
Jan 20, 2010 | IBM NetVista PC Desktop
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Mar 06, 2009 | IBM NetVista A40 PC Desktop
Very slow boot on NetVista P4 1.6
This sound like a hardware compatibilty issue. What is the model of your NetVista?:
Feb 08, 2009 | IBM NetVista PC Desktop
Not seeing a option to boot from cd rom
In the boot sequence you have to set the cd drive as the first bood drive.
Jan 11, 2009 | IBM NetVista PC Desktop
IBM Netvista desktop bios problem
this is more like a workaround that I used on a laptop which cd room drive just failed (and which I did not want to replaced as it was more expensive than the whole laptop)
If you can't select the device you want to boot from.. you may want to partition your hdd and format it so it loads a dos operating sytem .. use another machine and a win98 startup disk to do this then copy your I386 folder from your winxp cd into the new formatted hdd so when you put the hdd back into the IBM machine it loads dos and then going into the I386 folder you can run a winnt command for you to install the os.
Jul 31, 2008 | IBM NetVista PC Desktop
First of all if you re formatted the drive You have lost ALL of the information on that drive. Next you don't need to go through BIOS in order to boot from a disk. You can press F8 on the screen that you would normally enter BIOS with.
Hope This Helps
All The Best,
RCF
May 28, 2008 | IBM NetVista A40 PC Desktop
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
90 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
