I Have the version NERO 6.3.1.26, and one LG HL-DT-ST
DVDRAM GSA 4163B dual layer dvd writer.
It is imposible to write with the MEMOREX 8.5 GO, 8x. ( video or data).
The maximale speed of me dvd writer is 4.5x.
It's impossible to change the speed, in the Nero options ( ex. to reduce 4.5x to 2).T
The ancients dvd Memore x 2.4 x, 8.5 GB was good!
Exemple of the LOG:
'' #21 Text 0 File DVDPlusDualLayer.cpp, Line 481
L0 Data Zone Capacity set to 500016 (7A130h, 976MB) -> ERROR, capacity different:
L0 Data Zone Capacity on disc: 2086912 (1FD800h, 4076MB)
L0 Data Zone Capacity requested to be set: 500016 ( 7A130h, 976MB)
13:36:04 #22 CDR -1135 File ThreadedTransferInterface.cpp, Line 1614
Erreur écriture
13:36:04 #23 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1614
Impossible d'effectuer la fonction Disc At Once
13:36:04 #24 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
13:36:04 #25 Phase 38 File dlgbrnst.cpp, Line 1855
La gravure a échoué à 4x (5 540 Ko/s)''
Thanks , Dan
If all you are looking to do is write a DVD (ie, burn ordinary OS-managed files onto DVD, without transcoding, etc.), or write transcoded DVD-structured files, or an .iso image file, then don't even try to use Nero. Use ImgBurn, it is 500% better for those kinds of tasks, and it's freeware. I use it to burn DVDs but use Nero to transcode files and create the VIDEO_TS folder files. I then use ImgBurn to convert them to an .iso file, then burn it to DVD, also using ImgBurn. URL: http://www.imgburn.com/
Sahaja Yoga is the Mahaa Yoga and is the Only Solution to all the Problems of World.
