Question about Tilia FoodSaver VAC420
We have a Tilia Profesional ii. The unit just stopped working with a sealed bag stucked. We cannot open the lid and three blinking green lights. Any suggestions?
I have the same problem, did you find a fix?
Posted on Jun 28, 2010
Do the Gsix and Ultimate G Kerby bags fit on the heritage II
yes this fits, kirby now have a universal bag to fit all models see kirby.com
Feb 19, 2013 | Kirby Heritage II Vacuum
Food saver is stuck shut
I experienced the same problem today. I forgot to reinstall the drip tray prior after cleaning it. I closed the Foodsaver back up and it got stuck in the closed position and would not open no matter how hard I tried. I would push the green tabs and attempt to rotate it as per the instructions and it still would not open. I was able to resolve the issue by taking a flat head screw driver and carefully prying a few inches in from the sides of the machine. More specifically, the drip tray is basically a rectangle catch basis with two half circles on either end. Place the screw driver at the location of the half circles and gently pry at the parting line where you would normally put the bags while pushing both the green tabs. Once the tray is reinstalled it should work fine. If your like me, you wont make this mistake again. Good luck!
Jun 11, 2012 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Jan 24, 2011 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
May 17, 2010 | Tilia FoodSaver V2240
Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Jan 08, 2010 | Tilia FoodSaver V2240
How do I turn on my tillia foodsaver my friend lent to me?
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Sep 28, 2009 | Tilia FoodSaver V2240
Foodsaver Profesional II heat strip transformer burned out.
The transformer can be found at a good wholesale electronics store, it is 12 volt and will register slightly higher with ohm meter. You can also use a 220 to 24 volt transformer.
Dec 04, 2008 | Food Processors
Tilia FoodSaver VAC420 Logo
824 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
