Question about Magellan Crossover GPS
I need to upgrade firmware on this unit - Magellan Crossover GPS
    President:
  • 1,111 Answers
There are actually a few different updates for this gps..the link im going to give is for the north american model..if you have one other then the NA model, stop here and ost back to me.
first youll have to determine which update you need by going in the system setting and locate the firmware currently installed..if its lower then 1.68 install the 1.68 first and do not just jump to the 2.14 update as it will throw all kinds of fits and probably make it unusable ...choose the 2.14 update to install if you have the 1.68 version currently installed
updates and manuals the the NA crossover can be found and downloaded HERE
if you have any problem or i have confused you in anyway, please post back before you attempt this update.
you will have to register your crossover before Magellan will allow you to download the update.
follow the installation to the letter as described in the update..i recommend the unit be plugged in to the home charger although magellan says make sure the battery is full.
bill
Posted on May 15, 2010
  • Ben Dover May 19, 2010
    im curious why you only rated my answer as a 3 TU? was something i told you incorrect? i fix these daily so im curious what the problem is?
    bill
Samsung sf-650 intermittently sends a blank page
Print configuration report "Menu>Reports>Configuration/System Data"
Check the firmware version. 1.07 or lower is likely to have this problem
Upgrading the firmware is quite simple.
Get the update from samsung website Samsung.com>Support>Search Box "SF-650">on product support page find tab "firmware" and download upgrade file.
If you feel competent to do the upgrade (read the instructions in the txt file twice) do it.
Be aware that the upgrade will likely want to do a memory clear once it is complete so you will loose address book etc. Also do not power off unit during upgrade or you will damage the firmware and possibly make the unit unusable.
Hope this fixes the issue.
Feb 21, 2011 | Samsung SF650 Plain Paper Laser Fax
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
RECEIVES FAXES OK, BUT ONLY SENDS BLANK SHEET
Feb 16, 2011 | Samsung SF650 Plain Paper Laser Fax
Cannot read Xvid ... does exist a firmware upgrade
No. you will need to convert this format to a recognizable format that is compatible to this particular unit. there is not a firmware upgrade that will assist at this time.
Sep 25, 2009 | Thomson DPL906VD Theater System
My momrex mmp8565 is telling me it's having trouble booting up and then shuts down
Read you manual p. 59
http://www.memorexelectronics.com/manuals/MMP8565CFirstDraft10-9-07.pdf
If the unit acts erratically, reset the unit by inserting a thin object (such as a paper clip)
into the recessed Reset button. For the Reset button, see page XX for the
button's location.
FOR FIRMWARE UPGRADE
Please visit our Web site at www.memorexelectronics.com to check if there is new
firmware available.
IMPORTANT NOTE: Before upgrading the firmware, please backup all of your media
files on your computer. After upgrading, format the unit to complete the upgrade
procedure.
Sep 07, 2008 | Memorex Audio Players & Recorders
Firmware upgrade failure
Try this for the reset
First turn the unit off then
hold down the "Pure Direct" and the "Direct" buttons on the display at the same time. And while you are still holding them down turn the unit on with the power button on the display.
this should reset the microprocessor.
You will need to put all custom settings back in.
Let me know if this helps.
Dave
Jun 06, 2008 | Denon AVR-3805 Receiver
Firmware upgrades
Installing/upgrading firmware is usally not requemented. You will not be adding any new feature to u're unit. There's no reason to do reinstall or upgrade the firmware other than to repair the unit in the event the units firmware is corrept.
Johnny Delstar
Apr 26, 2008 | Delstar DS 31024 MP3 Player
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Coby MP-C756 Firmware upgrade issue
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is no longer displaying, unfortunately, it needs to be replaced. The unit can not be fixed because there is no firmware available for the unit at this time. The warranty is 90 days from the date of purchase. You would need the receipt in order to receive a warranty replacement.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Nov 19, 2007 | Coby MPC756 MP3 Player
Jukebox Zen Xtra 40 gig
You probably have Winders Media Player 11. If you can find another computer that has WMP 10, you can use that computer to do the firmware upgrade, then go back to the original computer. Thingsa should work fine. Otherwise, you need to unistall WMP 11 and WMP11 runtime. Another case of Billy messing us up. And don't even get me started about vista....
Aug 14, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Magellan Crossover GPS Logo
400 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
