Question about Nintendo Wii Console
Wii doesn't have power
Our wii has been working lately and then today the little light on the power button wasn't on. We checked to make sure everything was plugged in correctly and it was and we even switched outlets trying to get it to work but it still wasn't. We tried to turn it on repeatedly but nothing happened. Any ideas?
    Scholar:
  • 75 Answers
My wii has had the problem since the day I bought it, and what seems to work every time is to warm the console up. I don't know why it works, but it does, and it will power on. Unplug it and set it somewhere warm then plug it back in. It's worth a try, hope it helps :)
Posted on Jun 09, 2010
My wii went off after a thunderstorm and doesn't get on anymore, can I do something to fix it? I've already changed the battery inside but nothing cheanged.
First make sure the circuit is live - Are there other things on that circuit? Do they work? If not, check that the breaker hasn't tripped, and reset it if necessary. Next, check that that specific outlet wasn't damaged. Plug something else into it. Does it work? If not, the outlet needs to be replaced. Also plug the Wii into another outlet. If it works, this also confirms the original outlet has been damaged. If the Wii still doesn't power on, the power supply has probably been damaged. Unless you can replace it yourself, it probably isn't worth having it repaired.
Apr 21, 2012 | Nintendo Wii Console
Incripted wii remote
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
Dec 01, 2011 | Nintendo Wii Console
The Wii console light will turn green
Hi sharonkayh,
Try the following:
1) Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2) Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved.
This is done by:
  1. Make sure your Wii console is successfully connected online.
  2. Access the Wii System Settings.
  3. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  4. Select "Wii System Update" and press the A Button.
  5. Select "Yes," and read any messaging regarding obtaining the update. If you agree to the messaging, select "I Accept."
  6. The Wii console will now search for the latest Wii System Update.
  7. If an update is available, it will be downloaded and installed automatically.
I hope this can help you - Source: Nintendo Website.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 05, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
YES THE FIRST THING IT TO OPEN UR WINDOW THEN TROW THAT WII **** OUT THE WINDOW WITH ALOT OF FORCE UNTIL IT BREAKS THEN GO BUY YOURSELF A OTHER ONE
Mar 21, 2010 | Nintendo Wii Console
Wii Remote Turning Funtion Doesn't Work on Mario Kart
Your wii sensor bar probably went out, replace it. They sell wireless ones at wal-mart for $20. If you want to make absolute sure that the bar is broken, take a video camera and take a quick video of the wii bar while it's connected and the wii is on. If you see four little blue lights on each side then you're wii bar is ok, if any are gone it should be replaced. The fact that all the buttons are still working means that your wii is still communicating with remote using bluetooth, but since it's not sensing any motion, it probably means that the problem is sensor bar related.
Aug 25, 2009 | Nintendo Wii Console
Wii and Gamecube controllers do not work for Wii
Perhaps this is a stupid question, but have you synced your controllers lately?
Open the little drop over under the disk tray (the place where you put the SD card) and press and hold the red button in there, open the battery cover for the wiimote and press and hold that little red button. Wait till both the controller and the system respond. Basically, they have to find eachother again.
I hope this helps.
Caid.
Dec 31, 2008 | Nintendo Wii Console
We have recently moved home and our nintendo wii remotes have stopped working. i have checked all the connections and have put new batteries in them
Make sure the Wii is plugged in correctly and the light on the power button is on.
open the small panel in the front of the Wii and open the battery panel at the bottom of the Wii remote
and press the red buttons together
If you had been suffering from batteries lasting a little while then Nintendo will replace the controller for free
Jul 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
37 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
