Symphonic TV WF-13
This TV had been working fine. I have a dish network remote programmed to control the TV functions. When I hit the mute button on the remote it came up with a menu with the numeral 1 in each corner. I had not seen this menu before, and the only way I could get it off was to turn off the TV. Now the channels only go to 69 and none of them are viewable. I'm not sure if this is the problem but I can't find any way to change from cable to antenna in the menu that comes up with the menu button.
  • edawn1452 Sep 07, 2008
    same thing with my tv........will try all suggested..let you know tomorrow
I have had a problem like what you stated.
I turned TV off. Then unplugged the TV, for 5 mins.
Then plugged the TV back in the power outlet.
Also try the menu button on the TV itself, NOT the remote.
Scroll thru the menu button, with alt volumn & channel buttons
make changes.
Good Luck
JayHzg
Posted on Apr 02, 2008
I have an ol RCA tv, new dish remote everything works but the mute button...i can raise and lower volume, turn off and on but not mute
Hi there Stacey, my name is Kimberly and I form part of the Social Media Department with DISH. We do not promise that our remote will control all the functions of you TV. The codes used to program your DISH remote to the TV may be limited to some functions. You can try addressing your remote to the TV using different codes. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
You can lookup the different codes here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 27, 2014 | DISH Network Televison & Video
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
Having trouble getting my Dish Universal remote to connect to my Insignia 19" flats screen television. I think it is the silver (ES3189) model remote
traceroberso,
I came across your post. Are you still having problems with your DISH Network remote operating your Insignia TV? If you still are, I have 2 codes you can try to see if it will work on your TV. The codes are: 720, 539. The steps to program the remote to the TV are below.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network - Executive Offices
Nov 11, 2010 | DISH Network EZ Remote Remote Control
White westinghouse tv code for remote control? And the procedure to program it.
pepelule
Here are the codes for your White Westinghouse TV: 719, 500, 659, 664, 670, 672, 674
I have also included the instructions for programming the remote to your TV. I hope this helps.
  • Remotes: Basic (Television Only)
Ray Calo
DISH Network
Oct 25, 2010 | DISH Network IR Remote Control
My dish remote does not control my element tv do someone needs the codes?
castro_ed387, I am unable to provide you a code as I do not know the remote model, but the steps below will help in programming the remote to the TV, and I included a link on the bottom that has the codes on it.
Program to TV:
2. Press and hold the gray TV button on top of the remote until all lights turn on.
3. Let go and TV will be blinking, enter the three-digit code using the buttons on the number pad.
4. Press # and test functionality with the TV
5. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television. If it works press SAT.
Link for codes: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Tommy Faust
DISH Network
Oct 04, 2010 | DISH Network IR Remote Control
As I program my control of dish to a tv sanyo
Hi maria_pal371, I would need to get a better idea of what model remote you have. I would recommend viewing our remote codes found here:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
The model # is on the back of the remote at the top, once you have the code(s) you can follow these steps to program the remote:
1. Hold the gray TV button until all lights on top turn on.
2. Let go and while TV is blinking enter the 3-digit code you found and press #.
3. TV should blink a few times and stop. Try volume/power/mute.
4. If everything works hit SAT and you're good to go! If not repeat steps 1-3 with a different code.
Tommy Faust
DISH Network
Sep 17, 2010 | DISH Network IR Remote Control
What is the code for DISH Network remote on a Symphonic SC313E 13 in. TV/VCR Combo?
I hope that after all this time, you were able to find that code. But if you weren't, or you still have some questions, here are some steps and codes.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
733
632
694
Becki Barned
DISH Network Customer Service
Sep 03, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
I hope that you have found the code already, but if not, I am here to help!!! Follow the link below, which will walk you through programing the DISH remote to that tv. Very simple process!!!!
Becki Barned
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
Programming the remote for wf-13
I have the same exact problem also
Sep 07, 2008 | Televison & Video
Televison & Video Logo
322 people viewed this question
Top Televison & Video Experts
Electro Med Services...
