Question about Apple iPhone Smartphone
My iphone 2g died when hooking up to itunes -it lit up for a second and then went blank. Two complicating factors: 1) the usb connection is finicky. 2) the 'power' button doesn't work at all. I've got it taken apart now what can I do to get it working?
5 Suggested Answers
  • 4 Answers
SOURCE: My iphone is not detected by itunes
Put your iphone in the recovery mode and get out by ibrickr v9.*
Posted on Dec 27, 2008
no_pc-gst
  • 58 Answers
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Posted on Jan 02, 2009
jacko0
  • 159 Answers
SOURCE: IPHONE STUCK ON USB AND ITUNES SCREEN CANNOT CHARGE
It's sounds like your iPhone is stuck in recovery mode
Try this
Posted on Dec 18, 2009
  • 8 Answers
SOURCE: Restore Problem with iphone A1203 2g
Well, your SIM card must be compatible to your iphone carrier. From what I understand, so far only AT&T is able to give out SIMs for iPhones; however, that may have changed to the addition of another carrier (perhaps Verizon, or so I hear) If you have the correct SIM card, then I would suggest that you go to your nearest wireless store and ask for one that may help your situation. Otherwise, if you don't want to do that then just unlock your phone :) There are videos on youtube that you can look at, programs that you have to download and what not, but it's doable.... or you can take it to a side stand wireless and have them unlock it for you :)
Posted on Apr 16, 2010
My iphone was charged up then it went blank then wen i put it oo the charger its saying connect to itunes
You seem to have either entered restore or dfu mode your going to have to restore your phone
Feb 28, 2011 | Apple iPhone Smartphone
Getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
Feb 26, 2011 | Apple iPod touch Second Gen (8 GB,...
Itune is not working with unlocked 2G iphone
Hi, Please check the steps given below
1) Connect iPhone to your computer, Iphone should display an image or message on the display, Please check the iphone display
2) Check what operating system are you using on computer, iPhone requires a specific minimum version of iTunes. Windos should meet the minimum system requirement to use itune and iphone
3) Check if the computers Drivers and upto date
4) Check usb connection by swaping with other device like pen drive etc
5) Restart your computer
Hope this information will help you
Dec 10, 2009 | BoxWave Corporation Apple iPhone 2G...
Iphone dies and shows itunes picture
I fixed it. 1-uninstalled iTunes on the desktop. 2-turn off iTunes. 3- connect iPhone to USB wire to computer. 4- turn on iTunes. It detects it now. Then use restore. (damn it did not work) - 5- from number 2 onward repeated again. This tome it was restored.
Oct 10, 2009 | Apple iPhone Smartphone
A usb and itune with a arrow pointing at my iphone screan what should i do?
restore it using itunes.then jailbreak and unlock to work properly....here's how to connect w/ itunes....you must have an internet connection to restore...
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button ( 5 Second )
After 5 Second Press Power Button (9 Second )
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button
Your Iphone In D.f.u Mode With Blank Screen
done
Oct 03, 2009 | Apple iPhone Smartphone
I phone wont come on
restore it w/ itunes.then jailbreak and unlock.
Turn Off Your Phone
Release Home Button
done
after restoring w/ itunes jailbreak the phone and unlock.
Sep 18, 2009 | Apple iPhone Smartphone
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
How to upgrade the iphone 2g 8gb?
Simple get on a pc go to apple.com download iTunes the latest version... Open the app on your pc... Connect your USB cable and to your iPhone ... iTunes will detect it then it'll ask if you want to upgrade to firmware 3.0 then upgrade ..
Aug 24, 2009 | Apple iPhone Smartphone
Pc screen goes black when iphone connected with itunes running
Hello can you tell me if your iPhone is a 2G or 3G and are you plugging it into a USB 2.0 port?
if it's a 1.0 usb port that could be your problem.
the 3G doesn;t like anything but 2.0 usb and won't work.
the 2G is a little more forgiving.
also, is your phone pwn'd / unlocked
you may need to restore your iPhone and reunlock it.
I can help with that also.
if you wanna hook up on msn or yahoo let me know i will walk ya through it
May 31, 2009 | Apple iPhone Smartphone
Restoring iPhone
Hi. My 2G iphone was connected to Itunes and it was accidently disconnected...now the screen is showing a UBB cord with an arrow pointing towards the Itunes logo. can you help?
Oct 05, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
