Question about Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
Displays e4 wont work - Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
Posted on May 16, 2014
  • 4 Answers
E4 or E-4 error message in the Wolfgang Puck Pressure Cooker means that the pressure cooker is not sealing properly.
This is usually caused by the relief valve not properly seating. Usually you can get the relief valve to seat by putting a little pressure on the top of the valve and wiggling it around. This will rub off the layer of minerals that have built up on both the valve seat and the valve needle. If that doesn't work, pull the top of the valve out of the seat, and manually scrape off the buildup of the mineral buildup.
Not properly sealing can also be caused by a mis-alignment of the pressure cooker gasket seal. It sits in the lid part of the cooker. It can become a bit stretched. First note the location of the gaske, then take the gasket out and gently clean it. Put the gasket back in the lid and carefully put the lid back onto the pressure cooker. You can tell that it is properly seated if there is no gap between the lid and the pot. If there is a gap then the gasket is misaligned and so the lid is not seating properly.
Once you get the pressure release valve, and the gasket seal properly seated, unplug the pressure cooker to clear the E4 error message and try using the cooker again. Once the timer clock starts ticking down, there should be very little steam coming out of the cooker. Your pressure cooker should work fine now.
Posted on Mar 14, 2015
    Problem Solver:
  • 18 Answers
There doesn't seem to be any legit way of fixing this, except for trying to clean the pressure switch contact. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Posted on Dec 03, 2013
In the bottom of the cooker..remove the screws..theres the board and a spring device ...clean the spring device or just shake it ..it work for me..
Posted on May 29, 2012
    Problem Solver:
  • 6 Answers
Before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error
Posted on May 24, 2010
What does E 4 on display panel mean?????
Hi Noreen,
The "e4" is an error code. You need to search online for "error code e4 + your make". You should then, at least, know what the problem is.
Aug 25, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Keeps coming up E4Pressure cooker
Here is a piece from someone who had the same E4 error problem:
I had this problem. I noticed that steam was coming out almost immediately and the cooker would not start counting down. Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle. The plastic cover was so far down on the metal piece that it would not allow the metal cylinder to seat on the vent. You can use the metal piece by itself or work the plastic cap up far enough so that the metal piece seats on the vent in the closed position. I have had no more problems - it works fine. good luck! kc
Mar 18, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Error code keeps flashing wont pressure up and they wont stand behind their product
The vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Mar 09, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
Pics of process:
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Displays E 01
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
May 17, 2007 | West Bend 85146 6-Quart
Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver Logo
1,366 people viewed this question
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
Sloop Johnb
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
