Question about Maytag 24 in. MDB3700 Built-in Dishwasher
May Tag Dishwasher
My May Tag dishwasher dose not release the detergent.When cycle is finished,door is still closed.What can I do?
  • 164 Answers
Http://www.cpsc.gov/cpscpub/prerel/prhtml07/07094.html
I think you should review this webpageThere have been over 2 million maytag dishwasher recalls due to them being a fire hazard. The chart below came from the site and Im not sure what your serial number is but your model number is on there.
Brand Model numbers MUST
begin with… AND serial numbers MUST end
with… Maytag® MDB3, MDB4, MDB5,
MDB6, MDB7, MDB8,
MDB9, MDBD, MDC3,
MDC4, MDC5, DWU9 SM, SQ, SS, SU, SW, SY, SZ, UB,
UD, UF, UH, UK, UM, UQ, US, UU,
UW, UY, UZ, WB, WD, WF, WH, WK,
WM, WQ, WS, WU, WW, WY, WZ,
YB, YD, YF, YH, YK, YM, YQ, YS, YU,
YW, YY, YZ Jenn-Air® JDB3, JDB4, JDB5,
JDB6, JDB7 UB, UD, UF, UH, UK, UM, UQ, US,
UU, UW, UY, UZ, WB, WD, WF, WH,
WK, WM, WQ, WS, WU, WW, WY,
WZ, YB, YD, YF, YH, YK, YM, YQ,
YS, YU, YW, YY, YZ
Posted on Sep 11, 2009
SOURCE:
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher model FFD612EMBGS keeping half of the detergent in its location it dose not take it fully and some detergent powder snag on the dishs
Check to make sure you are not blocking the soap dispenser door with a large platter or pan in front of it. The water will not be able to wash out of it.....
Jan 29, 2014 | Frigidaire FFD612EMBGS DISHWASHERS FOR...
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
AEG Favorit fails to release detergent most of the time, but not always. Any thoughts?
There is either food debris blocking the action of the dispenser lid, or the solenoid which releases the door is sometimes failing to operate. The latter fault can be due to either a faulty solenoid or a loose/damaged cable connection anywhere between the main board and the solenoid: bear in mind that every time the door opens and closes there's a flexible connector which gradually fatigues and there are electrical connections which can be loosened if the door is regularly allowed to slam shut.
It's not really a DIY fix unless you are a competent and experienced home appliance repairer, but you can check for any food debris around the dispenser lid. If in any doubt run the machine empty using dishwasher cleaner. The possible electrical faults I've mentioned aren't necessarily expensive in terms of parts, but the labour will typically be about one hour.
An alternative is to use the new detergent dispenser from Finish. This sits in your machine, preloaded with twelve doses of detergent which are automatically released with every wash. It's an expensive way to buy dishwasher detergent, but it's a quick and relatively cheap fix which may buy you time until you can afford a proper repair.
If you do think that you may be able to diagnose and repair the fault on a DIY basis then I highly recommend the Haynes Dishwasher Repair Manual which you can either buy or perhaps borrow from a public library.
I'm hope that you have found my reply to be of use, all that I ask in return is that you take a moment to rate my answer.
Feb 28, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Washing tablet found unused on the bottom of the dishwasher...
Put the tablet in the bottom of the washer ,do a wash cycle,if the tablet is used up the washer is not releasing the tablet till the end of the wash, if the tablet is still there the water is too hard or the tablet is faulty.
Nov 29, 2017 | KitchenAid KUDK03ITBK Built-in Dishwasher
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
237 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
