Question about Whirlpool LER4634J Electric Dryer
Dryer gets too hot blows thermal fuse thermostats have been changed
SOURCE: Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Posted on Jan 04, 2008
Maytag317
  • 1136 Answers
SOURCE: Dryer not blowing hot air
Hi, If you use the automatic dry cycle, there needs to be heat in order for the timer to advance.
Remove the little cap in the front lower left corner and start the dryer. The ignitor should glow for about 15 seconds and then the gas should ignite. If there is no glow from the ignitor and the fuse is good, you will need to remove the front panel and check the senser on the burner, the ignitor, and the thermostats.
I hope this helps you. If you need more assistance on this issue, please let me know.
Vic
Posted on Jul 03, 2009
buffalonyman
  • 1865 Answers
SOURCE: My Whirlpool Dryer gets very hot, even at the air only
The problem that I see is that there should be no heat when running the air only setting. If you did not miswire anything, then I suspect the control board may have failed. You really need to use a multimeter to troubleshoot the machine so that you can see where the problem lies
Posted on Aug 03, 2009
  • 2180 Answers
SOURCE: Maytag performa Keeps blowing Thermal Fuse. Vents
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Posted on Mar 19, 2010
  • 44 Answers
SOURCE: Have replaced heat element, thermostat, thermal
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Posted on Nov 20, 2010
My gas clothes dryer is working,but it is not blowing hot air
The thermostat or thermal fuse could be blown. Usually happens when lint buildup blocks the exhaust exit & the heat stays inside the machine. So to prevent a fire, the thermal fuse or thermostat blows. You would have to enter your model # on google to find links to parts breakdown.
Sep 13, 2014 | Maytag Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
I replaced my thermal fuse on my pye2300ayw dryer now it gets to HOT
Whenever you change the thermal fuse the thermostat should also be changed...
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
THERMAL FUSE BLEW
A blown thermal fuse is an indication of a failed operating (cycling) thermostat. The thermal fuse and the operating thermostat are located on the blower outlet duct to regulate the temperature of the air inside the dryer by monitoring the temperature of the air going out. The cycling thermostat cycles off when the air gets too hot and cycles on when it gets colder than normal. Therefore when it fails to cycle off, the temperature gets too hot and when it reaches the temperature limit of the thermal fuse, the thermal fuse blows.
Apr 18, 2010 | Dryers
Model 110.68622700 keeps blowing thermal fuse.changed fuse a month ago
If the thermal fuse is blowing, it's because the inner dryer is getting too hot. The control thermostat is the likely culprit. It's not cycling the heating element is staying on continuously. I would change the operating thermostat. If you go to repairclinic.com., put in your make and model, it will pull up all the parts for your machine.
Sep 13, 2009 | Dryers
Dryer stopped working... wont turn on
Before starting troubleshooting-Unplug the dryer, because you will be removing front panel for this check.
There are several things that can cause your problem:
#1 of which is a clogged up lint trap and/or vent duct raising the heat that could cause your thermal fuse to open (blow). What to do: Make sure that duct and vent outside of wall are clear, if they were obstructed, then the thermal fuse can be checked for continuity with an ohm meter, it is located in the fan housing with 2 terminals coming off of it, if it does not have continuity (connection) between terminals, you will need to replace it, simple and less than $15 bucks.
NOTE: this problem can also be caused by a bad thermostat letting dryer get to hot which in turn blows the thermal fuse., sooo after changing thermal fuse you need to check that the temperature of air leaving dryer duct does not exceed 150 degrees, if it does replace the thermostat for less than $25 bucks, this maybe be what caused your problem in the first place. Good Luck!
Apr 28, 2009 | Whirlpool Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Whirlpool LER4634J Electric Dryer Logo
111 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
