Question about Speed Queen AWS52NW Top Load Washer
Speed Queen HD comercial washer
The main knob, that turns to select the apropriate wash cycle is broken, how do I fix or replace.
It will, with great difficulty, turn with friction from both thumbs to select the wash cycle, the pull to start knob in the center still works to turn it on when pulled out.
Please advise
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Posted on May 03, 2008
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
How do I replace broken washer cycle selector knob on speed queen top loader
Hello there and thank you for choosing fixya
These knobs are normally the pull off type so all you have to do is get a small flat tip screw driver behind the knob and gently pry it out to get it started then it should slide off
However if you are needing to replace the entire part then the top back section of the machine may need to come off it may even have some screws behind the white side plates that allow to be removed and the top part folds up and back allowing you to axcess the part ok this part is usually held on by 2 or 3 screws
Jun 29, 2011 | Speed Queen AWN412 Top Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Speed Queen model no.AFN50RSP111TW01 Washer makes humming sound all the time in off position,i am being told by dealer that its the transformer which is normal,replaced transformer and still hums,unplugged...
Usually a transformer hums when it does not have the proper voltage being supplied to it. I would check this first. If the voltage is correct contact a parts supplier and request a new transformer. Speed Queen has a great parts warranty. As Speed Queen is really a commercial machine it is not unusual to have them make more noise than other manufactures.
Dec 18, 2010 | Speed Queen ATS90AWN Front Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Queen wash machine
may be incorrect belt or gear box locking up.
Jan 04, 2008 | Speed Queen AWS75NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
580 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
