Question about SanDisk Sansa E280 MP3 Player
Reads Bad Track
I synced some new songs, and now the screen reads, "Bad Track", and freezes the screen. No buttons will work when this occurs. I went into my sandisk, and cleared all the songs, but when I go back to Windows media player to put them back in, it will state, "Already in player" or skipped.
Do I have to clear my media player as well, and restart?
If you changed the name of the song then thats the problem just simply change its name back to the original.
If thats not the problem then just delete the song or it will mess your sansa up and download it again for free with limewire. If freezes hold the power button for a long time untill it turns off.
Posted on Mar 30, 2008
Error when loading songs
Here's what another user did - let me know if it works:
ok so i called 1-866-sandisk and she told me how to fix it. you just flip the key lock at the top so you see orange, then hold down the record button. then you should get some sort of message on the screen. then you plug it in and under my computer a file should show up. you open it and make a folder in it called sansa.fwm (i think thats the right folder name, if not, try sansa.tmp or email me). then you unplug it and it should say formatting or something like that. once its done it should work.
Dec 17, 2008 | SanDisk Sansa E280 MP3 Player
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Transfering music from my computer to sansa 250 player
Common problem with this unit - if you have a good virus protection program, use Limewire and only download tracks that are in mp3 format
Aug 10, 2008 | SanDisk Sansa e250 MP3 Player
Bad Track
You will probably have to reformat the player, but the "bad track" message could also be caused if the songs you are trying to download have an expired DRM license.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa E280 MP3 Player
Help
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Jan 04, 2008 | SanDisk Sansa e260 MP3 Player
Cant down load songs i like
Go into WMP and connect the USB cable to your computer and player. Press the M button on the side til the screen reads "MTP." The device set-up wizard should start. Then hit the "sync" menu and drag and drop songs onto your sync list
Dec 25, 2007 | GPX MW3837 MP3 Player
Storage
The iLO manual says you cant get songs from music stores like Napster. Lime Wire works very well on mp3 players. This same problem happend to me but then i realize it doesnt work if the songs come from Napster
Dec 21, 2007 | iLO MP3 Player
Problems with Sansa e250
-Tha Mp3 Doctor
Aug 16, 2007 | SanDisk Sansa e200 MP3 Player
Sansa mp3 player 8gb won't play my songs. ("bad track" is what it says)
I think you need to format your player. Open up my computer, right click the player and click "format"
Jun 02, 2007 | SanDisk Sansa e250 MP3 Player
Cant transfer anything to my player (e250)
i'm having a similar problem. every time i sync new music my computer tells me its on, but the tracks aren't on the player. it also refreshes every time i turn it on, which takes forever amd is getting really annoying. could this have something to do with my new microSD card?
Mar 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
205 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
