Question about Burton Stria Snowboard 2008
The base of my burton stria 2008 delaminated the stripes are popping out but it is not under warranty anymore. i just recently bought the escapade est bindings so i am stuck with burton. The stria model is discontinued and this is my second burton board where the base delaminated. i bought this board because i was told it had a p-tex base and would not delaminate.
  • 66 Answers
You're situation is not uncommon. I have dealt with bases de-laminating like this several times in the past and it is usually always due to something causing the glue to become brittle and fail. Whether this due to wear and tear will depend on the condition the base is in. If the base is all torn up and has gouges along the edge of the rails then no one will take it seriously because it could have been water damage. If, however the base is in good condition then you should still have a chance of getting it warranted. Contact Burton or better yet contact your area sales rep, explain your situation and your loyalty to Burton (even if its waning a bit now) and ask them what they can do. If they are cool they will at least hook you up with a really good discount on a new board. Also if you ahve a good shop near you (or better yet the one that sold it to you) then go in and see if they are keen to help.
I always fought for people in your situation so with a little luck you will fond someone else who wants to help too.
Posted on Jun 08, 2010
Rv siding buckling near slide
Is it fiberglass or aluminum? Is the buckling at the top corner of the slide opening? Is the unit under warranty still? If it is fiberglass is could be that water has permeated behind the fiberglass and is causing the side to delaminate. If it is aluminum it could be that the staples have pulled loose or in both cases it could be a structural problem. Now, if it is under warranty then you need to get it to an authorized warranty service center ASAP. If it is not, you still need to get it checked out and depending on what is found your insurance provider may authorize covered repairs.
Jul 11, 2014 | KZ 2013 Sportsmen S321RKS
Coating inside oven has de-laminated and rust is forming under coating. Warranty?
Hello spark... no warranty unless the microwave is under 1 year. If there is a lot of rust and delamination you are best off to replace this oven.
The problem with delamination is that it exposes bare metal and can result in dangerous arcing.
If it is not real bad, sand off the rust and spray paint it with microwave cavity spray paint available at this link http://www.appliancezone.com/ShowProduct.aspx?ID=8338&AspxAutoDetectCookieSupport=1
Joe
Thanks for choosing Fixya!
Feb 20, 2011 | GE Microwave Ovens
Boy just got a burton hero board, put on his danny kass bindings. The EST system for binding attachment seems to stink. Only two screw attachment, they immediately loosen up. How to attach tighter?
The Hero is designed to work with Burton's special two bolt system. The base plate on the Burton bindings is much stiffer than standard (like the on the Kass's) so will flex and loosen quickly. The best solution if these were both bought together from a store is return them as they should not have been sold together. If this is not possible then sell the bindings and buy the correct Burton model. If this is not fixed the mounting screws will eventually damage the board and need costly repairs.
Mar 06, 2010 | Burton Winter Sports
How good is this board, compaired to the top brands like burton, and forum?
Prom is a basic "generic" brand which makes many boards under many names. They are simple boards sold at cheap prices and usually only come with a 60 day warranty which is a lot less than most big brands 1 year warranty.
Jan 14, 2010 | Raven Prom Snowboard 139
Slowing down at around 40km/hr, the transmission jerks.
2008 Tucson? It should still be under warranty. Does it have more than 100,000 miles on it? Are you the original owner? If not, does it have less than 60,000 miles on it?.. If so, it's still under warranty - take it in to get fixed under warranty.
May 11, 2009 | 2008 Hyundai Tucson
How do you attach goggles to a Burton RED helmet?? How do you open the ******** the back of the helmet?? I'm affraid to just pull really hard and snap it off.
If the back of the helemt has a bungee strap you have to pull really hard to get it out. Its a pain. if its just a clip slide it under (you probably know that but hey some people...). Hope this helps you!!!
Jan 15, 2009 | Burton R.e.d. Hi-fi Stigma Xl Snowboard...
Samsung LE37A659A Black Screen and White stripe
Get in touch with the retailer straight away, and have them fix it under warranty.That is why they give yoyu a warranty, so taht if anything DOESgo wrong, they can fix it for you.
Jan 04, 2009 | Televison & Video
I don't know how to change the ankle strap
You have to losssen the screws on the sides with the 04 models i believe. otherwise you push down and the pull the strap to the sideand it should pop out when you pull it back up. But I think the 04 year was screwed ninto the base.
Dec 28, 2008 | Burton GRIP FIT CAP STRAPS FOR SNOWBOARD...
Control panel of Defy Multi Function Oven not working
If the control panel has delaminated they are covering this under warranty from what I have seen.
Hope this helps Ya
Jun 17, 2008 | Hobart DEC502 Electric Double Oven
Burton Stria Snowboard 2008 Logo
393 people viewed this question
Top Burton Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
