Question about Garden
I have a Craftsman 32.8cc 2-cycle tiller model 536.797502. I have been unable to start. Cleaned the air filter and plug and put fresh gas mixture in. Any ideas?
Tiller starts but immediately shuts off
Replace spark plug
Pour out old fuel and replace with 2 cycle fuel. Plan gas will not work!
Sep 29, 2014 | Mantis 2-Cycle Tiller
Manage my life com sears
-Make sure has fuel. It should start.
Good luck
mai
Jul 09, 2014 | Craftsman 4-Cycle Mini Tiller
How do you change the primer bulb in a craftsman mini tiller?
some primer bulbs come as an assembly and have two clips that snap into the housing others are bolted in with 2 screws if so remove the screws and make sure to take what is left of bulb to match up the new one
Oct 15, 2012 | Craftsman 2-Cycle Mini Tiller
I own a 2 cycle mini tiller craftsman and I need a manual for it. I want to tune up tiller it's blowing smoke.
Manuals for many Craftsman tools are available here: http://www.managemylife.com/mmh/owner_manuals . Lots of tillers are listed just by searching for Craftsman tiller. If you can find the model number (usually on a plaque on the housing of the tiller), you can narrow down the list greatly.
I hope this helps.
Mar 31, 2011 | Mtd Craftsman 4Cycle Mini Tiller
I bought the Craftsman 4-Cycle Mini Tiller , Model# 29937 at Sears this morning. It did not has a manual. How can I get the manual ? Thanks Le
Your situation is puzzling and in fact on the Sears site with your tillers' parts list, they state the manual is no longer available with no replacement either. See item no. 92 on parts list.
Here is the parts list and diagram if there are any help to you.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/All-Products-Parts/Model-917299370/0247/1508000/00010290/00001?blt=06&prst=&shdMod=
Don't fear. Here is a link to a 6.5HP Craftsman tiller that I also hope will help. This model is a close relative but has rear tines.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0912306.pdf
Oct 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Craftsman mini tiller starts good but will not idle nor run fast
i'm having the same problem. cleaned carb but didn't help. I found that if I spray starting fluid on the gasket between the carb and the motor it speeds up. I'm going to try to find a new gasket, I can't tighten it anymore.
Good luck
Jun 30, 2009 | Craftsman Gas Mini - Tiller/Edger
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
