Question about Hayward Navigator Pool Cleaner
Ball bearings are gone from one of the four holders inside
Having difficulty removing the pod. I have removed the cap on the side and the screw. How do you remove the pod sectionthis is an older model a pol vac plus. Thanks
  • 25 Answers
Use a flat head screwdriver and slowly work it underneath the pod and work the pod away from the body.
www.cpo2go.com
Posted on Dec 03, 2010
How do I level my pioneer pl-50 turntable platter
When you removed the platter were there a couple of brass or copper washers around the spindle? If not you could try and find a couple to lift platter. Also check for wobble in the platter new ones can be had. There are clubs you may have to join on facebook that will help you one is Vintage HiFi and stereo mostly a bragging site but very helpful with links to others. that is where I found help with my Pioneer turn tables, also Ebay is where I found parts bought a PL518 sold for parts to fix the two I had.
Nov 17, 2015 | Pioneer Audio Players & Recorders
I want to install a new shwer head fixture. I am having difficulty removing the ball joint adapter. any ideas?
You have to remove the whole pipe going into the wall, the ball is not seperate. Use a pipe wrench or something similar to remove it. A new showerhead pipe needs teflon tape wrapped clockwise on the threads and screwed into the fitting inside the wall. Now you can install any shower head you want.
Jul 26, 2011 | Price Pfister 15 Series, Bell Shower Head...
Need to remove center console to replace seat belt. After removing 12 screws, console is still firmly in place. What else has to be done?
  1. Remove the two oval covers from the sides of the floor console. Remove the four (two on each side) retaining bolts. Lift or remove the front seat center armrest from the floor console.
  2. Remove one screw from the top rear end of the floor console (directly under the front seat center armrest.
  3. Remove four screws retaining the utility tray beverage holder to floor console. Lift or remove the utility tray beverage holder from the console.
  4. Remove two screws (directly under the utility tray beverage holder) retaining the front end of the floor console to the console panel front mounting bracket.
  5. Lift the floor console from the front and rear console panel mounting brackets.
Feb 27, 2011 | 1996 Ford Explorer
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
How do I remove the piston on a 1957 Chev Belair power steering cylinder?
YOU HAVE TO REMOVE UNIT FROM CAR.REMOVE THE CONTROL VALVE ASSEMBLY AND THE ACTUATING LEVER.REMOVE THE PITMAN ARM SHAFT ASSEMBLY.REMOVE THE CAP SCREWS HOLDING THE UPPER END COVER TO THE HOUSING AND REMOVE THE END COVER.USE A SMALL PUNCH OR SCREWDRIVER TO REMOVE THE OIL SEAL FROM THE COVER BE CAREFUL OF THE NEEDLE BEARING.NOTE THAT IDENTIFICATION NUMBER OF THE BEARING IS INSTALLED TO THE OUTSIDE OF THE COVER.PULL THE RACK PISTON BALL NUT AND THE WORM ASSEMBLY FROM THE HOUSING.REMOVE THE PISTON RINGS FROM THE PISTON REMOVE THE BALL NUT RETAINING SCREW. TURN THE RETAINING SCREW HOLE DOWN SO THAT THE BALLS AND THEIR GUIDE DO NOT DROP OUT AND SLIDE THE BALL NUT AND WORM ASSEMBLY OUT OF THE RACK PISTON.REMOVE THE BALL GUIDE FROM THE NUT AND TURN THE HOLES DOWN.THEN TURN THE WORM BACK AND FORTH UNTIL ALL THE BALLS HAVE BEEN CAUGHT ON A CLEAN CLOTH.THERE ARE 23 BALLS.THEY HAVE A DEFINITE SIZE AND MUST BE REPLACED AS A SET.THEIR SIZE IS STAMPED ON THE END OF THE BALL NUT.REMOVE THE BALL NUT AND ADAPTER FROM THE WORM.REMOVE THE RETAINING RING WASHER AND SEAL.FROM THE NUT SIDE OF THE ADAPTER.CHECK OVER THE BALL RETURN GUIDES AND CLIPS THE RACK PISTON THE BALL NUT AND THE WORM.THE WORM AND BALL NUT ARE A MATCHED ASSEMBLY IF ONE IS DAMAGED BOTH MUST BE REPLACED WITH A NEW SET.DO NOT DISTURB THE END PLUG IN THE RACK PISTON UNLESS IT IS LOOSE.IT CAN BE DRIVEN OUT FROM THE INSIDE OF THE RACK PISTON.STAKE THE NEW ONE IN PLACE AT FOUR POINTS.THE END PLUG IN THE HOUSING IS DRIVEN TO THE OUTSIDE BUT IS INSTALLED FROM THE INSIDE.IT SHOULD ALSO BE STAKED AT FOUR POINTS.
May 04, 2010 | Chevrolet Chevy Cars & Trucks
Center console disasembly instructions . we are trying to remove the center console
Base Console, Floor, Ranger, Explorer Removal and Installation
  1. Remove the two oval covers from the sides of the floor console. Remove the four (two on each side) retaining bolts. Lift or remove the front seat center armrest (644A22) from the floor console.
  1. Remove one screw from the top rear end of the floor console (directly under the front seat center armrest.
  1. Remove four screws retaining the utility tray beverage holder to floor console. Lift or remove the utility tray beverage holder from the console.
  1. Remove two screws (directly under the utility tray beverage holder) retaining the front end of the floor console to the console panel front mounting bracket.
  1. Lift the floor console from the front and rear console panel mounting brackets.
Apr 01, 2010 | 1996 Ford Explorer
I will usually use a large screwdriver. Wedge it in at the axel of the pod and gently pry it on one side then the other. It will slowly come away from the axel. That is all there is to it. Good luck.
Mar 21, 2010 | Hayward Navigator Pool Cleaner
I have Minolta Pocket 8x24/8.7, 40 year old binoculars. One side is "limp" and doesn't stay in position for viewing. Fix??
Most compact binoculars have a central bridge. The objective (big lens) end of the binocular hinge usually has a ball bearing in it. The other end may either have a blanking cap or a hub where the neck strap attaches. Removing this cap or hub will reveal a grub screw which tightens another ball bearing against the bridge. Take the appropriate part off the limp side and look for the grub screw. Tightening it will decrease the "limpness". Be careful, as these are sometimes set in place with a locktite of some kind. Best to release pressure first before tightening.
Jan 31, 2010 | Minolta Activa Pocket Binocular
Hoover U5750-900 just shuts off
I have a similar bagless model U5757-900 that is shutting off. I disassembled the unit, and what I found is that the motor front bearing had accumulated enough grime so that the bearing locked up. When this happened, the bearing outer shell spun in the plastic housing, causing it to soften, from friction heat. This allowed the motor shaft to become off center from the normal, centered axis of rotation. Once this happened, the rotor inside the motor began to rub against the stator, the fixed part of the motor inside. This loaded down the motor, causing excessive current draw, which caused the overheat switch to activate, shutting down the machine.
In your case, it might not be as bad as in my case.
Remove the dual-cannister dirt cup.
To find out, disassemble the unit lower section: on bottom, remove 4 screws around the rotating brush housing. Remove the brush cover, then remove the brush, then remove the belt. Remove the wide plastic housing behind the brush. Remove the two screws, from the bottom, that retain the upper hood. Remove the hood.
On the back, remove the two screws and hose retainer going from the base to the upright section. This releases the hose from the lower section.
Now press the tilt release, and lay back the upright section. Remove the four screws, two on each side, from the trunnion caps, where the upright section tilts on the lower section. Remove the trunion caps. Remove the upright section from the lower section.
Remove the headlight cover (2 screws).
From the back, remove the single screw retaining the bezel above the headlight area.
Slide the bezel upwards and remove.
Remove the four screws that retain the motor cover clamshell. One is from front, and other 3 from rear.
Open motor clamshell halves to expose motor.
Note orientation/position of the three wires on the motor, and remove those wires. Lift motor out.
To open the motor, gently tap the edges of the impeller housing (aluminum shell) on the edge of the shell, in the little gaps around the shell.
Using a 1/2" socket, remove the nut in the center of the impeller. This is a LEFT HAND NUT. TURN RIGHT TO LOOSEN IT.
Gently wiggle the impeller while pulling until impeller comes off of motor shaft. Use a glove so the impeller doesn't cut your hand.
Remove the large flat washer on the motor shaft. Remove the small sleeve from the motor shaft.
On the brush end of the motor, using a small screwdriver, pry out on the brush holders. Set them aside.
Remove the two screws holding motor together. Seperate the motor front from motor rear. Withdraw the motor rotating part.
Look into the inside of the stator, inspecting for bright, shiny areas where the rotor may be dragging on the stator. If you see these, then the front bearing, in the plastic motor frount, is fried. I don't think Hoover sells this part alone. Also inspect the plastic front bearing retainer to see if there is any melting that has allowed the bearing to become off center.
In any case, if there is scrubbed out places inside the stator, then the motor requires replacement, about $70 for the motor... You might be able to find an entire new vac for less... or, like me, find one on the side of the street where someone has tossed out a unit.
You may luck out and find that the impeller unit is just filled with some trash so air cannot get to the motor for cooling... or you may have a shot motor.
Jan 03, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hayward Navigator Pool Cleaner Logo
154 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
