Question about Thermador Kitchen Ranges
I have a 6 burner Thermador Gas Cooktop SGS456ZB. I have a problem with one of the ignitors. It keeps firing the entire time the burner is on. The other 5 ignitors and burners including the 2 extra-low burners works fine.
    Scholar:
  • 83 Answers
Dear Kathynearing,
Hi. I have experience cooking in a burner like that it keeps on burning coz the ignition coil was press by your switch knob coz the spring was stack up try to release it so that it will not be ignited all the time when your cooking. This should be ignited at once. If it gives light already it should be released. Please reply if you have solved the problem so that I can give you more advices.
Posted on Jan 13, 2009
Gas cooktop igniter keep clicking
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Mar 06, 2011 | Thermador SGS36GS Gas Cooktop
All ignitors not igniting on model # sgsx365cs, 5 burner cooktop.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 19, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
The cooktop igniter wont stop firing even when turned off
one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad.
Jan 13, 2010 | Cooktops
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Thermador SGS304 Ignitor does not spark
Hey Frust1
check that the particular burner is properly "grounded" see that no "dirt" is between burner and frame. Also ensure that the insulation on the wire from the igniter unit to the probe at the burner is not damaged.
Regards
Aug 14, 2008 | Thermador SGS36GS Gas Cooktop
Thermador 30" gas cooktop SGCS304RB
Do you hear gas? If so, take a needle and put it through each one of the small holes where the gas comes out.... Also look for a little "white-dust" where the sparker makes the spark. (located probaly at back of burner). If there is a white dust build-up scrape it off with something (needle) and give her another go...
Jan 21, 2008 | Thermador SGS36GS Gas Cooktop
Kitchen Ranges Logo
260 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
