Question about Microwave Ovens
I HAVE A WHIRLPOOL SLIDE IN OVEN MODEL RS385PXB
I have A whirlpool slide in oven there is an error on the screen that says F-3 can anyone tell me what this is or means... The oven stops heating when the error code comes up? how to fix it or what the part number is so I can order it.
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven
Yes, it could be. The first thing to try is a "hard reset".
Unplug it from the power line for a few minutes, plug it back in, then try again.
Let us know if the hard reset doen't fix it.
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
bestdarngood
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Posted on Mar 02, 2009
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
heavyt15
  • 91 Answers
SOURCE: Whirlpool MH1150XMB-0 runs but does not heat food
hmmmmmmmmmmm heat cook spin..jump up and down....myh guess magnetron..is gone
Posted on Aug 18, 2009
Testimonial: "Helpful. I now know what's wrong and think I probably can't fix it myself."
Whirlpool microwave won't heat up
Take two screws out and slide the grill to the left to clear the door
Oct 16, 2013 | Samsung SMH7178STD Microwave Oven
How to remove from wall
cabinet above should show three large screw heads going down into oven. When these are remove, the oven reseases. The back bottom edge is hooked on a metal plate so the oven will tilt forward. BE CAREFUL! They're on the heavy side. Remove all things in oven and if you can slide the stove away and stand closer to the wall it will help you carry the weight. I do it all the time, but you have to be ready for the weight. Let me know..........s
Apr 11, 2012 | Whirlpool GH5176XPQ 1100 Watts Microwave...
My new Whirlpool Microwave oven is now showing an F7 on the screen and will only turn on for 3 seconds. What should I do?
Hi and welcome to FixYa, I am Kelly.
The F7 = HV SMPS feedback error. Most of the time this is a costly microprocessor board issue but can be something as simple as a loose or broken wire.
If it is in fact new you should contact Whirlpool for warranty service. Anything you would do as a consumer will void the warranty. First make sure your microwave is registerd via this link where it says "Register your product" http://www.whirlpool.com/custserv/index.jsp
Then using that same link you can schedule service or find out where your nearest carry in service center is.
Online Service Scheduling:
https://www.whirlpool.com/service/error.jsp?country=US&lang=en&brand=WP
CONTACT WHIRLPOOL
(866) 698-2538
Mon-Fri: 8am - 10pm (EDT)
Sat: 12pm - 5pm (EDT)
email: http://www.whirlpool.com/custserv/email_form.jsp
If the unit is second hand or out of warranty please include the model number in your next response.
Thanks for choosing FixYa,
Kelly
Dec 21, 2010 | Whirlpool Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Jun 17, 2017 | Whirlpool MH3185XP Microwave Oven
Door open button is broken, door will not open
door button mechanism is all behind the control panel.
there should be a couple screws holding the control panel on, you can see them when you open the door i believe.
you probably need to slide it one way or another to get it to unhook from its hidden catches..
there is the outer button you press with your hand thats available in 3 colors depending on your model #, and then the inner latch..
it will need to be checked to verify which parts are broken..
hope this helps,
best of luck,
ttfn
Oct 18, 2009 | Whirlpool MT4155SP Microwave Oven
Replace control panel on whirlpool microwave mh1140xmq
There are two screws in the vent cover (grille)that goes across the top remove those and the vent cover and you will see one screw in the top of the control panel remove that one,grab the panel slide it up and pull at the top,it hinges downward toward you and will stay there till you get the wires marked and removed from the board.
Sep 13, 2009 | Whirlpool MH7140XF Microwave Oven
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
