Question about Dell Dimension E310 PC Desktop
System will not start. Four green lights on solid. Button light on solid yellow main board? cpu?
  • 3,940 Answers
Mainboard or something attached to it
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Posted on May 15, 2010
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Just wall switch works transmitters won't light
You probably have the opener lock turned on. Press and hold the lock button on the wall button pad for four seconds. The green light will go solid instaed of flashing
Jun 14, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
May 19, 2010 | Dell Dimension 2400 PC Desktop
System will not start. four green lights on solid. button light on solid yellow main board? cpu?
Hello
Could be a bad stick of memory,try taking one out then starting pc.
Do this to all sticks.If pc starts then keep that stick out.
Second,try to check that cpu is secure and fan is working.
Mar 21, 2010 | Dell Dimension E310 PC Desktop
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Not the power supply!
Hi
To help troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights lites solid green. The power button also lites solid green. If the computer malfunctions, the color and sequence of the diagnostic lights as well as the power button helps identifies the problem.
First, disconnect the power cord and remove all connections (Keyboard, Network, Mouse etc) as well as optional PCI Cards. Connect up the power cord (Monitor as well) and try powering the PC.
Check the diagnostic lights/system lights color and sequence and check the link below for more info (Assuming you have another system that can access internet)
Diagnostic Lights - http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
System Lights - http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1114432
Reply with lights color and sequence as well as any beep codes and I will respond at best effort.
Mike
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
System does not start
The beeps are error codes and if you listen carfully you will hear a pattern of short and long beeps. If you can identify the pattern we can help you figure out whats going on....
Feb 14, 2007 | Dell OptiPlex GX110 PC Desktop
Dell Dimension E310 PC Desktop Logo
104 people viewed this question
Alun Cox
