Question about Kenmore 73952 Gas Dryer
My kenmore dryer heat very good but the drum stop working it dose not spin at all
  • 10,319 Answers
The belt has broken off inside tjhe dryer
Posted on May 18, 2010
Propane Kenmore front loader dryer drum won't stop spinning and there's no heat.
EITHER OUT GOT A BAD DOOR SWITCH AN. BAD PART THAT CONTROL THE GAS TO YOUR DRYER BUT SEND THIS IS A PROPANE GAS DRYER IF U NEVER WORK ON ONE IT BE BETTER FOR U AN YOUR FAMILY SAFE TO CALLL FOR SERVICE
Apr 03, 2015 | Kenmore Dryers
Why dose a eletric kenmore dryer 70 seires the dryer runs about 1minute then turns off
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Jun 22, 2014 | Kenmore Dryers
Why dose a electric kenmore dryer 70 seires the dryer runs about 1minute then turns off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Recently, my dryer stopped spinning. The heat still works but the drum will not spin at all. Help me please :(
If you are brave enough to try undoing some nuts to open the dryer up you will probably find that the belt that wraps around the drum is broken or has slipped off of the drum. I bought a new one and did the repair myself.
Oct 16, 2010 | Kenmore 62622 Electric Dryer
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Kenmore 73952 Gas Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
