My pc turn off after e few minutes
My pc start up normally and after a few minutes just turn off and the power button just blinks
  • 1 more comment
  • Anonymous May 06, 2008
    its always restarting
  • nitejohn Sep 06, 2008
    My PC started to power down after a few hours use. I lost a record score n minesweeper and emails I was writting. Its really annoying. I'm trying the hibernation fix now and I'm bookmarking the page and will report on results soon.
    Thanks
  • Anonymous Nov 06, 2008
    when i try and copy anything my pc shuts down also i can't access my second hard drive it says windows explorer needs to close and when i try and switch it on it takes ages has it can't find my hard drives please help has it's driving me mad.
    Scholar:
  • 117 Answers
It sounds like you have "Hibernation" mode activiate. Try these steps to re-configure Hibernation....
It can be configured to kick in automatically via the Power Options Properties screen. In the screen capture below I've selected the Portable/Laptop power scheme that includes a setting to put the system into hibernation mode after 3 hours of system inactivity.
my pc turn off after e few minutes - sp32-20040707-141822.gif The Advanced Tab in Power Options Properties gives you the option of setting Power buttons to invoke hibernation. Many keyboards contain a 'Sleep' key that is very convenient to use with hibernation as illustrated in the screen capture below.
You can select "NEVER" in the pull down menu....
Let me know if this helps!
~~Jasta~~
Posted on Mar 30, 2008
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
NORMAL Wash light is blinking and I can't CANCEL wash. GE Quiet Power II PROFILE dishwasher. Started a normal wash and a few minutes into it the NORMAL light started blinking and can't find a way to reset.
We had the same issue with ours...tried turning off at the breaker, still didn't reset. Contacted appliance repair who came in and unplugged it from underneath the sink, waited a few seconds and plugged it back...dishwasher reset and repairman charged trip charge and labor $65 BUT problem is resolved and we now know what to do in the future.
Jun 09, 2009 | GE Dishwashers
I cannot turn on my Gateway m-6309 notebook. When i try to press the power button all I see is blinking light on power button and wi-fi for 1 minute and then it stops. I had a familiar problem 6 month...
have a few things for you to try. First take the battery out of the laptop and keep the power adapter connected, next press the poewr button down for about 1 minute. Then press the poewr button normally. should correct the problem. If the doesn't work then try external monitor to see if it works on another connection. If it works then your laptop has a hard ware problem causing the problem. If you have a warranty now would bea good time to call them if the steps don't work
Apr 15, 2009 | Computers & Internet
Can not turn on laptop.
remove battery plug in power.startup.if pc still is flashing press and hold power button until pc shuts down.restart.everthing should be ok now.wait until os is loaded then insert battery.
the battery should not begin to charge.
Dec 05, 2008 | Toshiba Satellite A45-S120 Notebook
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
Computers & Internet Logo
681 people viewed this question
David Payne
David Payne
