Question about Coleman Sport 1850 Generator
I have a coleman 1850 sport madel.the unit runs
I have a coleman 1850 sport model.the unit runs well but the on/ off with will not shut the unit off!i do have ac output no dc. It starts up well I just want to get it back to store bought....
  • 905 Answers
Due to vibration, it is very common for 1 or both of the wires to fall the switch. Also, due to placement of the switch, it can also fail due to water running down the inside of the generator housing as well.
Posted on Jul 15, 2010
I have a coleman Generator 1850. It stalls when i
Hello, I would check the carb for being dirty inside. It sounds like the needle valve is dirty, or not adjusted correctly, or there is rust in the carburator and any of these can cause the fuel not to feed into the engine properly. A good cleaning of the carb and proper setting of the needle valves should clean it up. Also check the screen in the fuel tank on the fuel valve.
Jan 21, 2011 | Coleman Sport 1850 Generator
Coleman 1850sport plus when running pulses up and down it will only run properly with the choke half on and when shut off gas drains from carb, have cleaned carb three times no success help
double check the float ajustment and replace the needle valve for the float carb should be rebuilt kist run around $20.00 and the float about $6.00+ ajust the carb.
hope this helps
Sep 01, 2010 | Coleman Sport 1850 Generator
Coleman sport 1850...when turned on .fuel runs into and right out of the carb until line closed. generator not used for two months but fuel was tunred off and unit allowed to run until it ran out of fuel. ...
When you drained the carb chamber by working with closed line, the floater in the carb chamber has fallen down. After two months later you let the fuel in again, the floater remain in down position and could not shut the input needle valve.
You may try to knock sharply (but not very hard) the carb cover when full, before opening carb cover in order to check the floater and valve.
Aug 04, 2010 | Coleman Sport 1850 Generator
The lack of DC output COULD possibly prevent the stopping. There are likely fuse(s) between the low voltage winding and a rectifier to generate the DC. SOMETIMES these are even inside the generator cover.
Mar 21, 2010 | Coleman Sport 1850 Generator
Can't start my coleman 1850 generator
Need more info,
Does it turn over??
Does it have spark??
Does it have fresh petrol??
Feb 25, 2010 | Coleman Sport 1850 Generator
Coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Jan 18, 2010 | Coleman Sport 1850 Generator
Engine speed varies
If the unit was stored for a long period of time (6-12 mo.) with gas in it, you may have a gummed up carburator. This is the most common problem with generators (lack of use)
The carb. would have to be removed & cleaned, specificly, the high & low speed jets
Sep 04, 2009 | Coleman Sport 1850 Generator
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman Sport 1850 Generator Logo
164 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
