Morning trying to restore my computer to factory settings and i'm anthony
Hui
Posted on Oct 15, 2008
    Sergeant:
    Champion:
  • 293 Answers
What type of PC do you have? compatible or branded one? old or new? do you want to erase everything on your PC? or just suddenly the PC is asking for date and time.
Posted on Mar 30, 2008
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
Tip
How to restore an Acer Portable to Original Factory Settings.
"Restoring a system should be a last ditch effort in trying to repair a computer, since restoration causes all programs and many files to be lost forever. Restoring an Acer computer to its original factory settings can be done in a few easy steps."
  1. Click “Start” menu.
  2. Click “Programs.”
  3. Click “Acer Recovery Management.”
  4. Click the “Restore” button on the bottom of the dialog box that opens.
  5. Click “Restore System to Factory Default.”
  6. Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
  7. Click “Start” to restore the computer to the default factory settings.
on Jan 02, 2010 | Computers & Internet
I have a dell latitude d531 and I'm trying to restore it to factory settings, Cntrl + F11 does not work
You may perform a complete factory restore by following the steps mentioned below:
1) Unplug all printer, fax, modem and other peripheral cables or drives from the computer.
2) Turn the computer on. Press the "F8" key until the "Advanced Boot Options" menu appears. You must press "F8" before the "Windows" logo appears.
3) Use the down arrow to scroll to "Repair Your Computer" and press "Enter."
4) Choose your language settings and click "Next."
5) Enter the administrator's username and password. Click "OK."
6) Click "Dell Factory Image Restore" then click "Next."
7) Click the check box next to "Yes, reformat hard drive and restore system software to factory condition."
8) Click "Next." The computer now will be restored to its factory settings.
9) Click "Finish" when prompted. The computer will restart.
Hope this helps..
Jan 28, 2011 | Dell Latitude D531 Notebook
I have the "D" file with the information needed to
Here is the primary way to restore your notebook to factory setting:
1 Turn on the computer.
2 As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press .
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
If you have tried this and you still can get your system to restore, your may restore partition may be corrupt, you may also have a virus that is preventing you access to the restore files. Run an AV agent and retry your retore. If you still have the system disc that came with your notebook, you should be able to use them to restore the unit back to factory setting. Good Luck C2Solutions
Jan 24, 2011 | Dell Vostro A860 Notebook
Im trying to get my pc to go to its original settings factort restore
The only way to restore your computer to factory setting with all the software/bloatware as it came with your computer the first day you start it up, you will need the factory restore disk that came with the computer if one is provide, if not usually with e-machine product, which doesn't provide you with a factory restore disk, you will have to create one yourself using a dvd-r. Usually you will have to go the the emachine recovery/back up management option in your menu programs and use that program to make the factory restore disk, after making that disc, you will need to insert the disc, and shuit down the computer and restart it. It will prompt you to follow direction once the factory restore disk is boot up. Follow the directions and you should be good to go. If there isn't a recovery managment program or a factory restore disk provided, you will need to contact emachine up.... usually they can send you factory restore disk for a small fee.
Jan 20, 2011 | E-Machines (T2958) PC Desktop
How do i restore my desktop to factory settings
To restore back to factory settings if it is dell then for xp it is ctrl + F11 on boot and select dell factory image restore for vista it is F8 on boot select repair your computer login using ur account and then select dell factory image restore.
For other manufcturers try Ctrl + F10 or F9 on boot.
Aug 11, 2010 | Computers & Internet
Ibm restore to factory setting
You have not explained what is wrong with your computer.
Is the laptop working, does it boot up into Windows?
What are you trying to restore?
Are you trying to get into a previous Restore Point?
The Access button takes you into the BIOS, you can change the BIOS settings back to the Default settings (ie the factory default settings).
It is difficult to offer a solution without knowing the exact nature of the problem.
Nov 23, 2008 | IBM ThinkPad R50e Notebook
IPod 4 gig mini blue
try to reset the nano
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Mar 30, 2008 | Apple iPod nano
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
