Question about Admiral AW22 Top Load Washer
2 leaks i noticed water leaking under washer, when i turned it over to inspect i noticed oil leaking from center of unit, where the belt attaches to it. can you give me any advice on what the problem might be. thank you, tony
  • robert samples May 11, 2010
    whats the brand and model number
    Scholar:
  • 116 Answers
I had the same problem, found a gold jewelry chain gone through the machine and was wrapped around the central spindle on top and part way through the main spindle seal, you should remove the agitator first for a look, I carefully pulled mout the chain with no damage to the seal, you may also need to remove the drum. I looks a big job but is straight forward.
Posted on Apr 13, 2008
How often do I need to service a BMW 123d?
Hi and welcome to FixYa. I am Kelly.
Here are your service intervals:
NOTE Besides Oil changes there are inspection intervals I & II
http://www.savagebmw.com/Service/content_service_Intervals.htm
Inspection interval I
BMW Inspection I (return to top) Undercarriage
  • Change engine oil and filter while engine is at normal operation temperature.
  • Check transmission for leaks.
  • Check rear axle for leaks.
  • Visually check fuel tank, lines, and connections for leaks.
  • Check condition, position, and mounting of exhaust system. Examine for leaks.
  • Check power steering system for leaks.
  • Check overall thickness of front and rear disc brake pads.
  • Examine brake disc surfaces.
  • Clean brake pad contact points in calipers.
  • Grease wheel center hubs.
  • Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  • Check front control arm bushing for wear.
  • Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  • Check all tire pressures (including spare). Correct if necessary.
  • Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks.
  • Check coolant level and antifreeze protection level; add coolant if necessary.
  • Check level of brake and clutch fluid in reservoir; add fluid if required.
  • Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  • Check air conditioner for operation.
  • Reset Service Indicator.
Body/Electrical Equipment
  • Check battery electrolyte level and add distilled water if required.
  • Perform batter load test.
  • Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  • Check instrument panel and dashboard illumination.
  • Check all warning/indicator lights, check control.
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  • Check wiper and washer system(s); wiper blades, washer jet positions.
  • Check condition and function of safety belts.
  • Oil hood, trunk/tailgate, and door hinges.
  • Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Check central locking/double lock.
  • Replace microfilter or Acc. Cabin Filter.
  • Check heater/air conditioner blower, rear window defogger.
  • Check rear view mirrors
  • Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  • Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection interval II
BMW Inspection II (return to top) Undercarriage
  • Check thickness of parking brake linings.
  • Half-shafts; check for leaks at flexible boots.
  • Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  • Replace spark plugs (as applicable by year and model)
  • Replace intake air cleaner element.
  • Replace microfilter or Acc Cabin Filter.
Final Inspection
Service indicator lights if installed:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
That should just about cover the works other than failures.
Thanks for using FixYa!
Kelly
Feb 16, 2010 | 2008 BMW 1 Series
Water leak from somewhere around the fan belt?
It is the water pump. The seal is leaking and ruptured.
You must replace the water pump. Can't just install a seal.
The water pump has a pulley attached to it.
Oct 07, 2009 | 2003 Chevrolet Impala
My car is over heating and cokkent oil is leaking
Cars generally overhead when engine coolant is below acceptable levels. That can be caused from leakage, blockage or equipment malfunction.
  • Inspect coolant level in the vehicle's reservoir or radiator.
  • Inspect radiator and heater hoses for cracking causing leaking.
  • Inspect the radiator for leaking.
  • Inspect the inside of radiator for smudge build-up, a sure sign that the water jackets might be restricted.
  • Inspect water pump for leaking or broken belt (serpentine belt)
  • Check to ensure water pump properly functioning, does the pump's pulley turn?
Repair or replace any faulty item.
Sep 09, 2009 | 2001 Mitsubishi Eclipse
Machine leaks when clothes are washed but not
this could be a simple issue or a severe issue.
if you feel adventurous disconnect unit, and remove Rear access panel. inspect the rear bearring at the pulley, check for oil leakage and water residue. if there is water around the bearring the unit requires an overhaul. if nothing you should be ok.
it could be a disconnected vent at the top of the machine.
remove front access panel and inspect all rubber boots and connections for water.
this is best done just after washer has leaked, inspect where water is comming from.
there are many things that could be causing this.
Jun 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
What is required in the service of a 3.0l subaru liberty at 100000kms?
your owners manual will tell you exactly. usually all filters should be changed (oil, air, auto transmission if equipped, fuel, cabin air etc) as well as spark plugs and wires, distributor cap and rotor if equipped, check the belts and hoses as well as the charging system. All fluid levels should be checked and topped off. Check your tire p.s.i. as well.
Mar 20, 2009 | 2004 Subaru Legacy
2008 Yahama 90 2 stroke outboard lower unit fluid leak
Ok by fluid I assume it is gear oil leaking yes?
There is every chance there is the smallest seal leak there that may only be present once the gear case gets a little pressure in it, either through use, or through expansion as the leg heats sitting in the sun even. Have you got a new washer installed under this screw to properly seal it? Usually a nylon type washer is best.
Also, how do you know the lower unit is not leaking or have water intrusion? Have you drained the gearbox oil recently? If so what color was the oil, milky looking at oil or good semi-transparent oil color?
Mar 16, 2009 | Boating
Water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Dec 29, 2008 | Maytag SAV2655A Top Load Washer
Washer
You bet, the tub seal is out and also the clutch and drive tub assemblies need to be replaced because like a drum brake oil has contaminated the pads. Did you notice that if you open the lid while spinning that it takes longer than seven seconds for the basket to stop? See the pic below, you need parts 1 and 5 plus the tub seal and center post seal.
Sep 30, 2008 | Washing Machines
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Admiral AW22 Top Load Washer Logo
87 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
