Question about Yamaha 83 1983 Xj750 K Midnight Maxim Generator Alternator Stator Coil
How do you remove the rear tire on a83 xj750 - Yamaha 83 1983 Xj750 K Midnight Maxim Generator Alternator Stator Coil
2 Suggested Answers
  • 156 Answers
SOURCE: how do you remove the rear tire on a83 xj750
With the bike on the main stand, Take out the rear axle and disconnect the rear brake linkage, on removal of the spacer on the axle the wheel can move away from the drive hub enough to disengage the drive spline and should wheel straight out the back of the bike.
Don't be concerned, these are less hassle than a chain drive to do!
Posted on Mar 21, 2010
Testimonial: "thanks this was very helpful"
Where is the alternator/generator on xj750
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
xj750 alternator generator location Google Search
Easy stator rotor removal
Yamaha XJ750 Owner Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Dec 16, 2013 | Yamaha Motorcycles
What is the largest size tire that will fit on the rear?
Hi, Bill for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
driveshaft clearance on 83 xj650
Largest tire that fits on stock rear wheel
Yamaha XJ750 Owners Workshop Manual
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Aug 03, 2013 | 1980 Yamaha XJ 650
Remove and replace rear tire on a 1980 Yamaha Maxim 650 XJ650G
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Xj650 Maxim 81 removing rear wheel
2008 Vstar Rear Tire Change
Jul 29, 2012 | 1980 Yamaha XJ 650
HOW TO REMOVE REAR WHEEL
How to remove the rear wheel of your shaft driven motorcycle
Mar 14, 2012 | 1983 Yamaha XJ 650
HOW TO REMOVE REAR AXLE 1983 YAMAHA XJ 650 MAXUM
1983 Yamaha XJ750 remove generator
Hi, Gmccadden for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.bikermetric.com/techtips-2-the-xs650-charging-system
1983 Yamaha 920 Virago stator replacement part one
Yamaha XJ750 Owner Manual actually it's a service manual
Jan 18, 2011 | Yamaha Motorcycles
Where is the spare tire located on a 1995 ford aerostar?
Section 00-02: Lifting, Jacking and Spare Tire Stowage 1995 Aerostar, Ranger, Explorer Workshop Manual
TIRE STOWAGE Tire, Spare, Removal, Aerostar If the Aerostar is a standard length vehicle the spare tire is mounted inside to a carrier at the left rear quarter panel. To remove the spare tire, remove the wing nut and plate. A flat tire can be temporarily stowed in the same location.
If the Aerostar is the bus with a standard length body or extended length (all models), the temporary spare tire is stowed at the rear of the vehicle under the body. The Aerostar standard length E-4WD bus spare tire is mounted on the floor.
  1. Insert lug nut wrench into the actuator hole and turn counterclockwise until the cable extends to allow the spare tire to be pulled rearward from under the vehicle.
  1. Slide spare tire to the rear and remove the retainer from the wheel.
  1. To stow cable/retainer with spare tire removed, insert cable fitting into carrier rear wall slot, place wheel retainer against the carrier, and turn lug nut wrench clockwise until slack is removed.
please rate, thanks
Jul 09, 2010 | 1995 Ford Aerostar
1983 Yamaha XJ Maxim 750. Rear tire rubbing on driveshaft
Hi, Blzofaz for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
rear tire rub normal
May 25, 2010 | 1985 Yamaha XJ 700 S Maxim
How to remove the rear tire with shaft drive
Pull the rear axle, and spacer on the brake side of wheel. Un hook brake rod and brake strut. Position yourself on the brake side of the bike and pull the rear wheel straight out of the final drive housing. Put a little grease on thhe final drive splines upon reinstalling the wheel to aid removal next time.
Apr 01, 2010 | 1979 Yamaha TX 750
Mar 21, 2010 | 1983 Yamaha XJ 650
Yamaha 83 1983 Xj750 K Midnight Maxim Generator Alternator Stator Coil Logo
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
