Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
My Kenmore Gas Range 760's oven light won't go off. Im not sure if it's the door (it looks closed) or what but the switch won't work...and it's been on for several hours now! help!
  • 15,935 Answers
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Oven is model 665.95781. I used the cleaning cycle.Oven door will not open. Message is E1 F5. Please help!
Based on your description, the E1 F5 error code likely indicates that the door latch is not operating.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
Mar 20, 2011 | Kenmore Ovens
My Kenmore Elite gas range is beeping and flashing F90, the door is locked. What can I do to clear this?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
Aug 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore gas range, light in oven won't shut off
the switch on the catch in the door is sticking . make sure there is no obstruction in the catch or the the wires on the switch are not shorting
Jan 28, 2010 | Amana AGR5715QDS Gas Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Oct 05, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven light
Heat causes metal to expand. Expanding metal can make contact with other objects, like a ground that completes a circuit. Take the lamp assembly apart and check for exposed conductors. Also, check the door switch. If it is heating up and something within the switch is expanding then the switch may be closing due to heat. With the door open puch the switch all the way in and see if the light goes off. If it does then replace the switch.
Deepwater
Apr 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Range oven door
try holding the door switch closed and press cancel. that usualy takes care of it. if that doesnt work send your model number out and this will help.
Sep 26, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
57 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
