Question about Texas Instruments TI-84 Plus Calculator
I need to find the equation for some points with my calculator but they are for an exponential regession. How do I do this?
  • Texas Instru... Master
  • 7,993 Answers
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. TO CLEAR OLD DATA
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. RUN the SETUP EDITOR Command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. TURN DIAGNOSTICSON option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DiagnosticsOn
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. ENTER THE DATA
Press [STAT][1:Edit]
Type in your D (X ) values in L1 and the N (Y) values in L2 (see picture 1). Sorry the picture does not have YOUR values.
TO OBTAIN THE STATISTICAL RESULTS (optional)
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (THESE~ARE NOT YOUR RESULTS). Your results will be different.
Notice the down arrow next to n=7. That means the results screen has more valuesI need to find the equation for some points with - ab847d7.jpg down arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow onI need to find the equation for some points with - 37fb2ba.jpg line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the satistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
E. PERFORM A REGRESSION ANALYSIS
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. In this step you must select the exponential regression model.
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [0:ExpReg]
  3. The command ExpReg echoes on main calculator screen.
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While ExpReg command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have ExpReg Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results. (These are your actual results)
You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
DRAWING THE SCATTER PLOT AND BEST FIT CURVE ON SAME SCREEN
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] and press ENTER to open plot1 configuration screen
  3. Use arrow to highlight On and press ENTER
  4. Use the down arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOI need to find the equation for some points with - b3dea28.jpgigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is activeI need to find the equation for some points with - d6e8e98.jpghe line Mark you can choose the appearnce of the raw data point.
And here are your two graphs: the raw data scatter plot and the line of best fit on the same screen. On the picture the ZoomStat option was used.
Now, it is up to you to accept this model or to try another model.
Posted on May 16, 2010
How to find values of x in higher order equations(above cube) on casio 570 ES?
In equation mode, you have system of linear equations (3 unknown) you have polynomial (quadratic and cubic), and solver. Use the solver foe any type of equation (nonlinear, polynomial of order higher than 4, trigonometric, exponential, logs).
May 21, 2012 | Casio Scientific Calculator Fx-570 Fx570...
How do you find the equation of a exponential graph
Usually ypu know the equation then graph it. However in doing statistics, it may appear that the curve of best for a scatter plot could be could an exponential. In that case you use the STAT application to enter the x-data in List 1 and the y-data in List 2. When you finish press the f1 key to select Graph1. You should also verify by Pressing F6:set that the graph type is set to scatter, and that List 1 contains the x-data and List 2, the y-data. After you verify that all is in order press the F1: Graph 1 key.
As the graph is displayed you will see several tabs with various regression models. Pan thr tabs to the right to get to F2:EXP. Select it.
The equation is displayed on the next screen. At the bottom of the screen you see two tabs COPY and DRAW. Press f5:Copy to copy the equation in one of the y= functions.
Press Draw and you will see the curve of best fit superposed on the scatter plot points.
Aug 23, 2011 | Casio FX-9750GPlus Calculator
Is there any way you can find the derivative without saying a point value?
Do you mean as in a linear equation? If so it is simple the slope of the equation. If you are referring to an exponential equation the derivative is always changing so no.
Sep 23, 2010 | Texas Instruments TI-Nspire Graphic...
Won't Graph Exponential Function
Ok, try these two things and you should be just fine.
1.) Check your range for your graph. It is possible that the range you are using isnt large enough to show the curve. Also try using Z-fit vs Z-st. These are options that your calculator will give you once the equation is graphed.
2.) Place a parenthesis around the 2x, make sure that you and the calculator are both using the same order of operations. This move mill ensure that the calculator will multiply the variable, x, by two and then do the exponential.
This should do it!
Happy Graphing!
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
How to find the best fit for exponential decay?
The error comes from the vanishing values at the tail of the function. The exponential function does not vanish except for -infinity. Truncate the lists by removing the pairs (5,00 and (6,0) or fudge up the data (5, 1E-5) (6,1E-6) and you will get your equation of best fit.
I am including a link to a post of mine where I show how to perform an exponential regression. JUST IN CASE you need additional information on the subject.
Apr 14, 2010 | Texas Instruments TI-84 Plus Calculator
I need to find the equation for some points with my calculator, but they are for an exponential regession. How do I do this?
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DIAGNOSTICSON option. To access the command
  4. Press the DownArrow 9 times to reach DIAGNOSTICSON
D. ENTER THE DATA (ENTER your own data)
Type in your X values in L1 and the Y values in L2 (see picture 1).
TO OBTAIN the statistical RESULTS (optional)
Here is a sample of what one gets .
Notice the Down Arrow next to n=7. That means the results screen has more values. Press the Down Arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
The screen captures with 2-Var Stats summarize all the statistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have To perform a regression analysis.
Here are sample results.
You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked To obtain.
  4. Use the Down Arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here plot1 is active (ON), it is scatter plot (first icon) the XLIST is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
Mar 21, 2010 | Texas Instruments TI-84 Plus Calculator
Exponential Grwth Equation
Input in this order:
ON/C
1.0025
LN
X
12
Apr 16, 2009 | Texas Instruments TI-30XA Calculator
Reposting! exponential and log equations
Use this entry sequence:
4 LN / ( 4 LN - 2 X 3 LN ) =
or this one which evaluates the divisor first
4 LN - 2 X 3 LN = 1/x X 4 LN
Dec 14, 2008 | Texas Instruments TI-30XA Calculator
Exponential and logarithmic equations
You re-asked this question more clearly and I answered it.....
HOW DO YOU ENTER r2 ON A TEXAS INSTRUMENT CALCULATOR?
No need to enter R squared. If it has meaning it will display in the stats variables screen ( 2nd F7 ).
Hope it helps.
Nov 12, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Calculator Logo
255 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
