Question about Freezers
How long should I leave my bosch KGN34X61GB to defrost? When can I turn it on again?
  • 30 Answers
A good normal manual defrost is 24hrs.
Posted on May 19, 2010
2 Suggested Answers
SOURCE: how long should I leave my bosch KGN34X61GB to
xp games not play in my os windows 7
Posted on Mar 21, 2010
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
I have a Kenmore upright freezer model# 253.9260210. We noticed that our food was starting to thaw. I opened up the coil area and noticed a small piece of ice on the coils. I melted the ice and turned...
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
Dec 08, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Whirlpool French Door Freezer on the bottom not cooling and freezer freezing up
You have a dfrost problem if at all possible remove food from refrigerator and unplug it, leave the doors open. By morning the freezer should be defrosted and that will buy you time to fix or call someone. defrosting can be quickened with use of a hair dryer. This is only a TEMPORARY fix and freezer will need to be defrosted again after 4-5 days.
Jun 18, 2009 | Whirlpool Freezers
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
A constant loud rattling noise throughout most of the day and night from a KGN33V60 model, appearing to come from the freezer compartment, for a very long time. This is the third replacement model we have...
Lots of stuff can cause noise. The only moving part in the freezer is the fan. I don't know of anything else that moves. If ice build up is an issue, then there are several things to concider.
Not enough defrost time. Cycle too short or heaters are not hot enough for some reason. Could be undersized heaters from manufacturer.(?) Defrost timer could be bad causing short or no defrost at all. This timer also controls the defrost heaters and compressor being off during defrost.
Be sure the seal around the door is tight. No air gaps. Warm air (contains moisture) will cause freeze ups. Long shot is that the thermostat is bad and unit never shut off. If timer is bad, compressor coudl be running during defrost cycle.
Hope this helps
Jan 15, 2009 | Freezers
Freezers Logo
85 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
