Question about Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker
Only 1 Kneading Blade is working. The other stops
Only 1 Kneading Blade is working. The other stops with any resistance. If I take the pan out the cogs that engage the Kneading Blades show the same problem. One has no give when I try to turn it. The other slips.
2 Suggested Answers
  • 433 Answers
SOURCE: Only 1 Kneading Blade is working. The other stops
Hi, Could be the belt is slipping or is worn for that paddle. Belts and motor are located in the base of the machine. Hank
Posted on Mar 22, 2010
Is there a spring that fits on the shaft/kneading blade?
I doubt if there was a spring on the kneading blade. It does sit a little bit loosely, this is normal
Jun 01, 2015 | Kitchen Appliances - Others
I need a new bread pan or kneading blade.
I need to know the make and model of your machine.
Mar 18, 2013 | Kitchen Appliances - Others
How do you keep the kneading blade from being baked into the bread?
Hi, You can take the kneading blade out of the machine after the last kneading cycle and before the final rise. Take the pan out of the machine to do this just to be on the safe side, Hank
Dec 06, 2010 | Sunbeam 5891 Bread Maker
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Mar 21, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
Kneading blade stays in the bread
I had that problem with my Zoji breadmaker. I sprayed a little non-stick spray on the blad and it worked. You can also spray the pan.
Jan 06, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Kneading Blade chattering
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Jan 02, 2009 | Sunbeam 5891 Bread Maker
Kneading blade stays in bread after cooking.
This sometimes happens. I have a Panasonic.
When you place contents in pan with some machines it is important to place contents
in a particular order. I should try to keep contents away from the kneading blade as you place them.
Another thing that might possibly help is to put a litter olive oil around the blade before adding ingredients.
Hope that this helps
Alleillia
Dec 02, 2008 | Breadman Kitchen Appliances - Others
Welbilt bread machine kneading blade stuck
I have the same problem. I have used Liquid Wrench and other products to no avail. *sadness* What a shame that I have a working machine but the pan is a goner.
Jun 10, 2008 | Breadman TR888 Corner Bakery Bread Maker
Bread machine pan and kneading blade
here's the manual if you need it http://www.bread-maker.net/Bread-maker-reviews/Product%20Manuals/Betty-Crocker-BCF1690.pdf freefone for spares from manufacturer: 1-866-819-4335 hope this helps :)
Mar 06, 2007 | Betty Crocker BCF1690 Bread Maker
Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker Logo
16 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
