Question about Home
When jacuzzi is on water turns yellow - Home
  • 349 Answers
If it has been just installed it may need running to clean out lines.
Also you can put cleaner in and run tub to clean out jets. Water setting in them may be causing this.
Posted on May 16, 2010
My client buy jacuzzi whit light and water jets but is not working the main control not turn on curse water in the plug all connections and not working..not guide any instructions
Jacuzzi Is STILL a viable SPA / Whirlpool Entity...
If you know the age of the equipment...
It may actually date back to when Jacuzzi
headquarters was right here in the San Francisco Bay Area.
Now SFSpas.com ... 510-527-5547
Paradise Valley Spas The Bay Area Top Hot Tub Retailer
Richmond, California (to be specific... (on Jacuzzi Street)).
((I was sad when they left).. but am still a happy customer).
Air "switches" remain their most popular trouble...
and if you know what yours LOOKS like... you
can VERY LIKELY still buy the parts from eBay...
I
recommend going to Jacuzzi... (opinion).
Carnac the Magnificent
Aug 09, 2017 | Jacuzzi Home
Jacuzzi tankless water heater code 12 appears
For my Jacuzzi tankless water heater model #J-SN180F: It turned out to be an exhaust issue. If I take off the exhaust vent completely then the talks heater works with 3 baths at full hot water. I get the error code 12 again as soon as I put event an elbow of the vent. So my conclusion is I need some sort of straight vent.
Apr 22, 2013 | Water Heaters
We have a hot tub or jacuzzi inside or on the side of our pool. We had a new heater installed. The jacuzzi should heat up very quickly but now the pool tech claims the drain from the jacuzzi is blocked,...
Is the equipment to heat and filter the hot tub separate from the pool equipment or do both bodies of water share a common heater and filter pump? In most cases they share a pump and heater with valves that direct the flow of water depending on how the pool owner wants to use the pools.
The first thing you need to determine then is if the equipment is working properly. Is there flow of water to and from the spa? If so, is the heater burner kicking on? If it is running, is it running properly with sufficient gas pressure, 3-4" tall bright blue flames and stays on continuously during the heating cycle for the spa?
What is 'very quickly' for the time to heat the water? In other words, if everything appears to be operating normally but the water is not warming fast enough or at all how much time is elapsing before deciding the heater is not working?
How old is this equipment and how much experience do you have with this pool tech or the company they are from?
Nov 07, 2010 | Jacuzzi Pool & Spa
Jacuzzi jets smell like rotten eggs when turned on.
Need to run some cleaner through jets to clean out old water and mildew.
May 09, 2010 | Home
Are you on well water? If so you may have dissolved iron in the well water, it enters your house as clear water iron and then once areated in the tub it turns yellow as the iron oxidizes. Another sure sign of this is if the water in your toilet yellows after sitting in the bowel with no use after a few days. Solution: have a reputable local water treatment company come test your water, test for disolved iron, total hardness, and pH. If the disolved iron is 5ppm or less then a water softener will fix the problem. Make sure they add a turbulator to the softener and use iron fighter salt or mix iron-out into the salt tank.
Mar 21, 2010 | American Standard Home
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Home Logo
70 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
