Nuvi 610 - External charging causes screen to freeze.
When I connect my nuvi to my PC via USB connector to charge the battery, the opening splash screen image freezes and stays that way until I disconnect the USB cable.
Also when I charge the unit using an AC adaptor, the screen again freezes but can only be unfrozen by pressing the nuvi Reset button.
Any adviced welcome.
Many thanks,
David707
  • David Peebles Apr 02, 2008
    Thanks Danasaur,
    I have solved the problem by buying a kosher Garmin AC Charger. The charger I was using was advertised as a "Garmin compatible" charger but cleary wasn't, so I bit the bullet and bought an OEM one.
    Thanks for your advice, which makes sense in the situation when the narrey is low but in my case it was showing fully charged.
    Manty thanks,
    David707
    Novelist:
  • 77 Answers
Don't disconnect it just because the screen freezes. This can happen if the battery is depleted too far, because the load is too great for charging AND running the device simultaneously. Leave it connected for 20 minutes or so, to see if the screen returns to normal appearance. If not, then you will be needing a new battery. Be sure to charge the new one BEFORE it is fully depleted. They are not NiCd batteries, so there is no need to fear ?memory effect". With NiMh and Lithium batteries, those days are gone, thank God!
Posted on Apr 02, 2008
SOURCE:
Charge indicator
Perhaps you want to charge via a USB connector on your PC. Could be the PC connections are not correct for delivering 5V on that connector.
The manual also says:
Connect the camera directly to the computer; do not use a USB hub or keyboard.
Please try to charge via the external charger that came with the camera. If that fails too, please try to replace the USB cable.
Nov 09, 2013 | Fujifilm FinePix T400 Digital Camera Black
Nuvi 285w stopped working after changing the battery
Most likely the flex cable for the display was pulled out of the connector on the main board. Also, if there is no sound, the speaker plug may not have been plugged back in. It may be plugged in but if the display is disconnected, you won't hear any sounds because you are unable to select any function with the touchscreen to activate a sound. We receive a lot of our repairs from failed battery replacements. The video makes it look easy but it is very easy to break something, especially if this is the first time someone attempts to do this.
Jun 02, 2013 | Garmin Nuvi 285WT GPS Receiver
Garmin 255w i replaced the battery, symptons of charging
Hello
There sill be a battery symbol in the forner of the screen which sill indicate advancing the charging signal [very like battery signal of a cellphone] in green color. You can see it on its manu page. To increase the accuracy of the battery guage, gully discharge the battery and then fully charge it. Do not unplug the Nuvi, until it is totally charged. Connect the vehicle power cable to the mini USB connector on your Nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for Nuvi to charge.
Connect an AC adapter [optional accessory] to the nuvi and a wall outlet.
Connect your Nuvi to a computer using a USB cable. The computer must be ON for the nuvi to charge. OK.
Jan 12, 2012 | Garmin nuvi 255W GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
My GPS is not turning on. I tried to charge but there is no signal. Can you please help me?
Are you trying to charge it with a car charger?
My Nuvi 1300 wouldn't start one day, and I tried connecting it to the car charger, and it still wouldn't turn on or charge.
I connected it to a PC via USB, and it would start up for purposes of data transfer, but after disconnecting it, it still wouldn't start. I found that you have to hold the power button for 10-15 seconds in order to force the unit to reboot. I've since found that connecting the unit to the PC was also an important if not necessary step. The last issue I had with my nuvi 1300, would not resolve itself until I plugged it into the PC, let it start up, and then unplugged it, in addition to holding the power button for 10+ seconds.
Mar 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Charging my nuvi 250 with a USB cable from my apple
When the GPS is hooked up to charge the battery it will say charging,try turning it on when hooked up and see if it is in fact charging,otherwise have you thought of purchasing a wall charger,I got mine on Ebay,very reasonable and works great,saves the hassle of hooking up to my comuter.Hope this helps with the problem.
Sep 29, 2009 | Garmin nuvi 255W GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
FROZEN SCREEN
By David707,
Since posting ma last re: Screen Freezing on external charge; I did manage to get the system back to some normality by pressing the Reset button located underneath the GPS Antenna flap. However this is likely to delete personally stored data on the system.
I should also state that the same problem occurs when I connect the 610 t my PC via the USB connection (another way to externally charge the battery).
A more satisfactory answer required though.
David707
Dec 28, 2007 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 360 power problem
You'll need to open the case and replace the battery. Batteries can be purchased online here or a couple other places on the web by searching for "nuvi 360 replacement battery". I'd get the 1400mah or greater for a replacement, it'll burn a little longer than the weaker models. If the unit operates when plugged into the charger, then the fuse and cable are good. Open the case by removing the retaining screws, then carefully prying the unit apart. The new battery simply plugs into the connector after removing the old one.
Nov 13, 2007 | Garmin nuvi 350 GPS Receiver
171 people viewed this question
Ekse
 Grubhead
Grubhead
