Question about Philips 60PP9352 60" Rear Projection Television
Phillips 37FD9944/01S Plasma TV - Power Supply
My Phillips 37FD9944/01S Plasma TV fails to come on and reverts to a flashing/blinking RED StandBy light from the GREEN power light. I have had it checked over by a TV repair shop to be told that it requires a new power supply, but that this is no longer available from Phillips....is there an alternative power supply I could use or does anyone know whare I might get 1 ? ....Actually 2 ...I bought another screen from eBay which has the same problem :-(
Thanks
Gary
  • 3 more comments
  • Anonymous Apr 11, 2008
    Tried caps and no help, From what i have herd the problem which is thermal is a fault with the small transformer. Simular to the standby trans in size on the power board. This is what appears to be the starting from cold issue is. I have herd that you might try resoldering the pins on the transformer. In the manufacturing process the coating on the windings must have not got cleaned enough to remove the coating from the connections. Causing a thermal resistance problem with the connections on the transformer. Have not found a source for a new transformer yet.
  • laurafey84 Jun 19, 2008
    I have the same problem. I need a new power supply panel for my Philips 37FD9944 Plasma. But apparently its been discontinued, does anyone know where I can find one?
  • fedja Aug 13, 2008
    replace kondensator 2663,2664 100uf /25v och 2662 1000uf/25v
    fedja@adamomail.se
  • paul hughes Jan 18, 2009
    i have the same model tv also from ebay i need a power board
  • lessjo May 11, 2010
    My tv went off for checking by insurance co as it fell whilst putting it on wall bracket and cracked the screen they tell me that the power board has failed can this be caused by an inpact as when i plugged it in it flashed the same as GSC60 problem on Mar 30, 2008. and they are trying to say it was something I knew about
Hello I hev a proble with PHILIPS mod; 37FD9944/01S chassis FM 33 AA.The picture of TV its blinking.Please halp me.
Posted on Jun 06, 2011
  • 149 Answers
Dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Posted on Apr 01, 2008
I have two Phillips TV's one LCD and a plasma. And i got the same problem. I called a technitian and they told me it was the motherboard, so I went and bought a new one and threw away my 37" LCD.The 42' Plasma although having the same problem it does turn on after plugging out and and in over and over couple of times.
Posted on Aug 12, 2009
  • philipml May 05, 2011
    got a Philips 42''plasma when I turne it on it switches off only way to get it to turn on is to unplug and plug in,worked after a few go's now I got to do it about ten times to get it going,very anoying,so is this the power supply causing this?
Power on flashes twice then shuts off
No. i think you have a power problem the switching power supply of your tv is damaged. But you can try to reset it if you know how.
Oct 18, 2017 | Emerson CR202EM9 TV
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Televison & Video
Phillips ambilight TV Flashing red LED light--- ^ long blinks and then 3 short blinks--- picture and sound will not come on---
Check the tv power supply board for those dying parts call copactors.That the board,where the power a/c cord plug into it.These capacitors are alway bulges or puffing up on it tops.U have tools and know basic electronic?Replaced those dying soon to be dead capacitors,will fix the power supply and have stable tv power again and tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 23, 2010 | Philips 50PF9731D/37 50 in. Plasma...
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
Vizio P4 Plasma TV, won't turn on
if your vizo p4 blinks red 10 times its your power supply board ckeck your two fuses on the board,if those are not bad change your power supply board if you can find a board for that model vizio p4 .the phillips tv uses the same board
Oct 11, 2008 | V, Inc. Vizio P4 Plasma Television
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Pioneer PDP506-HDG plasma tv
The 3 blinks ( i assume they're blinking in red) means a scan assy problem. Check the scan A & B boards and the Y drive board. Something is shorted and loading down the Vscan voltage of the power supply.
C-Dog
Dec 19, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Philips 60PP9352 60" Rear Projection Television Logo
5,017 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
