My neptune stacked washer and dryer continues to fill with water after wash cycle is done.
  • Washing Mach... Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing MachineMy neptune stacked washer and dryer continues to - 2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on May 15, 2010
Our Maytag stacking washer/dryer, MLE2000AYW, has generally worked well. Recently there is water in the washer after the clean clothes have been removed. The water can be removed by adding a spin cy
The intake valve may have debris under the plunger allowing the water to bypass the valve. If it fills up when not in use it is a sure sign of this. However, your issue sounds more like a clogged filter allowing drain water back in the drum after the cycle has ended
May 19, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
My washer fills VERY slowly and will not stop filling after cycle
It sounds like the water inlet valve is stuck partially open and needs to be replaced. It's located on the back of the machine where the hoses attach.
Jun 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
