Question about HP 4250 Monochrome LaserJet Printer
Fuser error 50.2
My hp laserjet 4250n can not initialize and has fuser error 50.2.i have replaced the whole fuser unit but it has not solved my problem.
  • 4 Answers
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
    New Friend:
50.2 FUSER ERROR
Posted on Dec 02, 2013
How to reset fuser unit in printer hp laserjet 4250
turn the printer off for at least 20 minutes, then cycle power. If the 50.2 fuser error occurs again, you may need to replace the entire fuser assembly OR you will need to replace the power supply.
Dec 24, 2012 | HP LaserJet 4250n Printer
I have hp colour laserjet cm6040f mfp, that displays error 50.A fuser error. pls your help is so much important
You will need to order a fuser and replace it or call a service tech who can. The problem is that the electronics on the fuser have actually burned out, so that is why the whole fuser needs to be replaced.
Aug 29, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
I am having printer quality issues with hp laser jet 4250n. All the words are blurry.
Replace the Fuser, it is behind the back door Part # RM1-1082.
Remove back door and push two blue tabs on fuser, remove and replace.
Jan 10, 2011 | HP LaserJet 4250n Printer
Sir, We have a hp laserjet 4250n printer since
Replace the fuser unit (they last about 75K pages in my experience)
1. Power down the printer and unplug it
2. Remove the fuser from the back side of the printer
3. Replace the fuser unit with a new one
4. Turn the printer back on
Dec 24, 2009 | HP LaserJet 4250n Printer
Dirty marks down centre of each page, has been cleaned but still getting marks, toner has been replaced also.
It seems you have a worn fuserunit. By replacing the fuserunit (RM1-1083) the problem should be solved.
Gerrit Jan
Oct 29, 2009 | HP LaserJet 4250n Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
50.4 FUSER ERROR ON HP LASERJET 4250n
I am willing to bet that you may have a faulty thermistor in your fuser asssembly, I wouldn't bother replacing the thermistor, your best bet is to just replace the fuser assembly and this should resolve your issue, so replace the fuser or call someone to do it for you. This should resolve your issue.
Mar 31, 2009 | HP LaserJet 4250n Printer
HP LaserJet 4 printing but binds up
Have you tried reinstalling the fuser? I am thinking the gears are not driving the exit rollers. If you purchaseda rebuilt fuser, there may even be a gear missing. Compare your new fuser to the old one.
May 09, 2008 | HP LaserJet 4 plus Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
HP 4250 Monochrome LaserJet Printer Logo
4,207 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
