Question about Compaq Armada E500 Notebook
Compaq Armada E500 PC Notebook usb port problem
I have a broken usb port (only one on the E500). Is it a big job to replace & does anyone have the knowledge to enable me to do it?
Many thanks in anticipation.
  • 2 more comments
  • DazzBodd Mar 30, 2008
    Many thanks, I'll be having a go next weekend.
    Having decided to have a go at this, I have removed all of the screws from the casing, somewhere in the centre of the unit there must be something still holding the unit together. Anyone have any experience of dismanteling an Amarda E500?
  • Anonymous Jul 28, 2008
    hi i am arsh
    i have a compaq armada e500 notebook. its usb port is damage.
  • jelistar Oct 19, 2008
    yep one usb port and the damn thing doesnt work. not impressed. if i take it into a repair shop how much should i expect to pay, anyone?
    Jeli
Have you heard of a pcmcia usb card? This is your solution. You can get some for like 10-40 dollars at NewEgg.com and other places. Most stores like tARGET AND bestBuy don't have them, yet and if they do, they are ridiculously expensive and not well supported by those tech guys. Go to NewEgg.com and purchase one. You can plug usb flash drives and other usb devices into a pcmcia slot - where your old wireless cards would plug into before laptops started becoming popular with internal wireless cards built in.
Posted on Aug 28, 2008
  • Compaq Master
  • 13,433 Answers
If the usb connector / port is only damaged it should be a fairly easy task.
Your going to need a few screwdrivers to get the laptop open
and a soldering iron, to remove the port or ports connector(s)
from the motherboard then replace it with a new connector.
if the motherboard is damaged you would most likely have to replace the whole motherboard and that would be way too much money for a few usb ports.
the usb connector only has 4 pins
http://wolfstone.halloweenhost.com/Audio/mpg016_ConnectorUSB.bmp
Posted on Mar 30, 2008
  • 1 more comment
  • Ekse Mar 30, 2008
    so you need to use the soldering iron to disconnect 4 pins from the motherboard then, 3 possible metal plateings witch keep the usb connector still on the motherboard.
  • Ekse Mar 30, 2008
    as you can see in this image, this is a male connector found in things you plug into a usb port
    http://farm1.static.flickr.com/187/48269...
    there are the 4 connectors and atleast 2 metals on the side keeping the connector still.
  • Ekse Apr 02, 2008
    If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
    Thanks alot!
Get a better notebook!
Posted on Oct 16, 2008
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
Usb stivk doesn't work
It seem to be a driver problem reinstalling the driver should resolve the issue.
Nov 02, 2010 | Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Broken Lcd hinges
No,you can't fix the hinges if they become slack, you wll have to replace the hinges,it's not too difficult on the E500.
Jan 21, 2009 | Compaq Armada E500 Notebook
Compaq armada e500 and webcam
The exceeding power cannot be fixed, the port are only allotted and capable of a certain power range. If the ports are faulty, they will need to be replaced, some are removable and some are soldier directly to the motherboard.
Jul 31, 2008 | Compaq Armada E500 Notebook
USB Connector
that or you could also try discount electronic stores for a usb PCMCI card to add in, then you have the added bonus of USB 2.0
Apr 21, 2008 | Compaq Armada E500 Notebook
Compaq Armada Serial Port Broken
Do you really need the serial port? You should be able to find a USB to serial converter fairly cheaply.
Sep 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
924 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
