it's simple goto profiles then you see the message tone option click on it and choose your choice of ringtone then press ok and select save option now your message tone will be changed.ued please don't forget to rating my solution.
Do a Samsung b3310 Master Reset: CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone. Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in)
hi, you have to go into settings, then profile now the top profile is general you need to then goto settings option on this general profile, try selecting the profile then if that dont bring up the profile menu then go back to where it says general then press top left or right button to enter the profile setup. once you have entered this you can scroll down and it will let you choose incoming call alert (this is your ringtone) and incoming call alert vol( this is how loud the ringer is) changing this will change the ringer you hear.
let me know how you get on or if you have any problems doing this
To change the ringtone, go to settings -> Phone profiles and click on the double arrow button. Here you can change the ringtone. You can also change the incoming message tone. to do that, you can select "new messages" in the upper right corner.
go to >settings >phone profiles >the profile you're set to, touch the >> >in the top right hand corner it says incoming and a drop down screen, touch it >new messages
:) hope it helps
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
