Question about Electrical Supplies
Wanting to install motorguide 24v trolling motor in boat will it work on just 12 v system
    Problem Solver:
  • 6 Answers
It should but may not run at it's intended potential. It may also run your battery down a lot quicker.
Posted on May 18, 2010
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a 2001 nitro bass boat an i am replaceing my 12v tolling motor w. a 24v. i installed the 2d battery and am ready to connect the wires. There are 2 positive wires, 1 states "battery a"...
Is this a straight 24V system... not a 12v - 24v.Correct..
The best advice is use a 50-60 amp resettable breaker..with 6 gauge wire (minimum 8 gauge) ... make sure your connections are clean, tight, and greased to prevent corrosion. USE a BIG HEAVY "jumper" cable between the + and - terminals.
Here are several sites that explain what you need to know..
I went from a 12-24v to a straight 36v Motorguide on my 21ft triton.. WOW!!!! talk about BAD A$$!!
I use the felt washers under all battery connections and the battery spray liberally on each connection..
24 and 36 volt Wiring Diagrams
24 volt trolling motor wiring Google Search
https://www.oreillyauto.com/shop/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/2000/ford/contour?sort=price+asc
https://www.oreillyauto.com/detail/super-start-4986/chemicals---fluids-16461/battery-chemicals-17661/battery-protection/01342/4742198/2000/ford/contour
https://www.oreillyauto.com/detail/bwd-3123/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/battery-cable/jc312/2601175/2000/ford/contour
Sep 18, 2017 | Nitro Boating
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Wanting to install motorguide 24v trolling motor in boat, will it work on just 12 v system
No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
Mar 21, 2010 | Electrical Supplies
Recently purchased a used 74# Maxxum 24 volt trolling motor to replace the 46# MotorGuide I had. It doesn't seem to be getting enough power it runs slower than the 46# Motorguide. Positive from motor to...
sound like either voltage drop or hi resistance from cables... if you test 24v at the plug then resistance is the problem and may have to rewire to a 6ga wire to carry the load, pretty simple just hook the new cable to the old one and SLOWLY pull it thru, help may be required because you dont want to loose it half way.....hope this helps...GL
Jul 03, 2009 | Boating
Electrical Supplies Logo
295 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
