Question about Indesit WA 115 Front Load Washer
Indesit washing machine wd10uk
Have taken door off to replace handle mechanism. But the srews holding the door were secured by fixings behind the machines outer casing. How do I access these screw fixings behind the outer casing to srew in the 2 door fixing screws.
Thanks
Russell
  • Anonymous Mar 15, 2009
    Exactly the same.
  • 32 Answers
Hi, you will have to remove the door seal fastener first, the just push the door seal inside the drum.
Posted on Feb 12, 2009
6ya staff
SOURCE:
Indesit IWDE126 door lock red light flashing/beeping
The door lock is mechanically/electrically defective and should be replaced.
Oct 15, 2018 | Indesit Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
Door problem Indesit WD 12 X
two ways
cut or break the handle off and you will expose the start of the door peg. this can be levered with a small screwdriver and the door will open.
or
take top off
feel down the front of the machine inside and you will feel the door interlock. sticking thro the interlock, you will feel the end of the door peg which with difficulty, can be levered with thumb nail so door opens
disconnect from mains first
Sep 09, 2008 | Indesit Washing Machines
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
Indesit WA 115 Front Load Washer Logo
230 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
