Question about Garden
Poulan wood shark carb tune up have a blue & red srew which one is low speed
    Brigadier General:
  • 4,088 Answers
Look for an H and L cast into the case or on the body of the carburetor near the screws.
Posted on May 15, 2010
How to adjust zama carb
start with your screws turned in. adjust the high screw to 1 turn and the low to 1/2 turn. this should get unit running. once running then you can fine tune the carb
Oct 09, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
How to adj the crab on a poulan chainsaw
if the engine is in good shape..screw in both carb jets adjusting screws till they seat lightly, then back them out 1 1/2 turns, srew in the throttle adj screw a turn and start the motor,,warning if the chain is on make sure the blade isnt likely to touch anything when the engine starts as you will have to have the brake off to get started and adjusted. With the engine running, adjust the throttle srew until it is idling just above shutting off speed, then adjust the "L" low speed jet to get the best idling speed without srewing it in much, reset the throttle srew, then , while trying to accelerate suddenly each time, open the Low jet a little at a time until the machine accelerates smoothly without hesitation. Reset the throttle srew to a position that the chain stops running at idle and check again that the acceleration is without hesitation ( usually with "L" jet about 1/4 turn out more than best idling). The high "H" jet can now be set to give the best power while cutting a block of wood.
Jun 29, 2014 | Poulan Garden
I borrow a poulan wood shark chain saw1950 a week ago from my brother inlaw . An old tree fell in my property and I used it for about 10 menutes and it stop running then I waited for 10 menutes and I...
did you fill it up with the ratio of 25-1 of fuel and oil?
if not then the carb will be block and will need cleaning out as it will be full of oil
hope this helps
John
Sep 09, 2011 | Poulan PP4218AV 18" Chain Saw
Poulan stalls out
on the side of the carb you should find two screws, one for the low speed jet nd one for he high speed jet. Turning the low speed jet only about a 1/4 turn at a time, adjust it in or out until it idles smoothly. Go to arboristsite.com, chainsaw and do a search on tuning for more complete info.
Jun 09, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Blue = "L"ow, Red = "H"igh If running just do the following:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If not running start with "H" and "L" 1.5 turns from lightly seated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | Poulan Garden
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
How do I do a basic tuning for a poulan pro 295? Just above the pull start are two access holes, one labeled "T", the other "L H". The saw is running pretty good, however I feel like it is not getting...
The `T` screw is your throttle control,the `L` & `H` is low and high speed. The normal procedure is to turn these two screws in full and then unscrew one full turn each. You start the saw and adjust the `L` screw gradually either way until it runs, do the same with the `H` screw while reving the engine. On some carbs. this can be tricky and needs a lot of patience, so if you are happy with the low speed only adjust the high speed. Hope this helps. Stephen.
Jul 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Needs carburator adjustment for poulan model # FL 26
Sure. (This will void your warranty and bypass smog requirements!) There is a red and a white limiter cap on the carburetor adjustment screws. Red= High speed / White = Low speed. Remove limiter caps. Turn both jets a 1/2 turn counter clockwise, Start, then fine tune. Use the low speed and idle screws to smooth out low to idle speed and the hi speed jet to tune the full throttle.
Apr 08, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
