Question about Coleman Roadtrip Grill LXE 9949-750
The axle of the wheels have broken the retaining nut inside the square tubing.
Your Coleman Roadtrip LXE has a wobbly wheel? No surprise. Since the axle bolt retaining nut on this grill is not usually securely welded inside the tubing, it will often break off, sometimes during initial assembly. If you have tightened it well,you have compounded the problem, since you now cannot remove the axle bolt. My best solution? Cut the bolt. The nut will fall harmlessly inside the square tubing and stay there. Next, remove the opposite side axle bolt and knock out the retaining nut on that side. Go to your local hardware store and buy a section of 3/8" steel bar stock long enough to reach through the square tube and extend through the wheels about 1/2" on each side. When you buy the bar, also buy two press-on wheel retainer caps to fit the bar. Place the bar through the square tube, slide on the wheels, tap on the caps, and replace the plastic wheel covers. Your wheels will no longer wobble - permanently.
Posted on May 26, 2010
  • 1 more comment
  • mechano-mike May 28, 2010
    The required bar stock for the new axle is actually 5/16".
  • Scott Ludwig Aug 16, 2013
    I just fixed mine in a slightly diffent way. In addition to the broken nut on one side, the cheap-o hollow plastic wheel was broken. I bought a pair of 6" lawnmower wheels at Home Depot. These have 1/2" ID holes for the axle. So I got a 1/2 stainless rod and cut it to just over 17" (14" square tube on grill, and 1.5" per wheel). I drilled and tapped holes in the end of this axle, and put a washer and pan head bolt in with lock washer. Also added a washer on the inside so the wheel isn't rubbing against the square tube. It's now better than it was new, but it just doesn't have the Coleman hubcaps anymore!
  • Scott Ludwig Aug 20, 2013
    Forgot to mention, reamed the 5/16 holes to 1/2.
    Guru:
  • 1,051 Answers
The part you need is called an 'inset washer'. Most large hardware stores sell them in a a variety of sizes. If you can remove the remaining part, take it the store fore a new one. They cost less than a dollar.
Posted on May 15, 2010
How do I remove a wheel?
It looks like you would have to cut the nuts off to get the wheel off . From you picture I cannot see any other way Will not be easy .But you will after be able to put better nuts on .
Apr 24, 2017 | Troy Garden
Remove rear brake drums
Light Duty Models
  1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
  2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
  3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
  4. Install the brake drum in the reverse order of removal and adjust the brakes.
Heavy Duty
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel. Loosen the rear brake shoe adjustment.
  3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
  4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
  5. Remove the hub and drum assembly from the axle.
  6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
To install:
  1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
  2. Place the hub and drum assembly on the axle and start the adjusting nut.
  3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
  4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
  5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
May 08, 2011 | 1991 Ford F250
I need to know how to replace the hub bearings on my grand am
The front wheel bearings on this car come as a sealed unit inside the wheel hub.
things you will need to replace them
-torque specs for your cars axle nut, hub retaining bolts, brake caliper mounting bracket bolts, and wheel lug nuts.
-a socket set
-a breaker bar
-a axle nut socket
-a c-clamp
-a jack
-two jack stands
To complete the job follow these steps
1) remove the hub cap/wheel center cap
2) remove the axle nut cap (use the tip of a small flat screwdriver to pry up one edge, pull it off)
3) remove the cotter pin from the end of the axle shaft
4) using a breaker bar style wrench (non-ratcheting socket wrench) with a helper pipe slid over the end to increase leverage use an axle nut socket to loosen the axle nut without removing it.(these are torqued pretty tight and can be stubborn, don't be afraid to use a generous amount of penetrating fluid).
5) once the nut is loose, loosen the wheel lug nuts
tip: doing steps 4 and 5 is made easier with the weight of the car on the ground to keep the wheel from spinning while you loosen the nuts.
6) jack up one corner of the car, and support it with a jack stand. lower the jack to rest the weight of the car on the jack stand, then lift the jack back up to contact the cars jacking point, without taking the weight off the jack stand. leave the jack in place as added support.
7) remove the wheel
8) remove the brake caliper from the hub (if you remove the caliper mounting bracket with the caliper still attached as a unit it's only two bolts to remove it together) hang it from the strut spring with some heavy wire or a metal clothes hanger being sure not to pinch or kink the brake line in the process.
9) remove the brake disc/rotor
10) locate the wheel speed sensor (a small electronic box located on the back side of the wheel hub) a small bolt secures it to the hub, remove the bolt and move the sensor to the side out of your way.
11) locate and remove the three hub retaining bolts (reachable from the rear of the hub)
12) remove the axle nut and use a jack stand to support the axle shaft
13) use a "soft blow" hammer (if possible) to tap on the back side at the outer edges of the hub working your way around in a circle so as to drive the hub out of its housing/steering knuckle evenly. As the hub comes out of the housing/steering knuckle the axle will want to slide with it, in turn pulling the axle out of the transmission. try not to let this happen. if necessary tap lightly on the end of the axle shaft to free it from the hub, once the hub comes loose remove it. this is where supporting the axle with a jack stand comes in handy. try not to allow the axle to scratch the hub mating surface.
14)clean the cavity that the hub came out of, remove the axle shaft support jack stand as you slide the new hub into place lining up the axle and the holes where the hub retaining bolts go (if you just shove it in, it can be impossible to turn it to line up the bolt holes) be sure that it is seated tightly against the steering knuckle, and that the axle is all the way into place. put the axle nut on but do not tighten it yet
14) replace the hub retaining bolts and torque to specs
15) replace the wheel speed sensor
16) replace the rotor/brake disc
17) replace the brake caliper and mounting bracket unit, this may require you to spread the brake pad pistons (this is easiest with a c-clamp slowly squeezing the piston open so as to not create too much pressure in the brake line or master cylinder). if a c-clamp is not available a large pair of channel lock pliers can do the job. once its in place, torque the caliper bracket mounting bolt to specs
18) raise the car off the jack stand, tighten the axle nut to snug and replace the wheel, remove the jack stand and lower the car to the ground.
19) torque the axle nut to specs
20) replace the axle shaft cotter pin and axle nut cap
21) torque the wheel lug nuts to specs
this should complete one side so switch your tools and equipment to the other side of the car and repeat the process. i hope this helps
Jan 05, 2011 | 1996 Pontiac Grand Am
How to change the rear bearings in my 1997 grand cherokee limited
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE MAKE SURE ITS ON A SOLID LEVEL GROUND.THEN YOU REMOVE THE WHEELS THE BRAKE DRUM OR DISC.THEN YOU REMOVE THE NUTS THAT ATTACH THE OUTER SEAL RETAINER AND BRAKE BACKING PLATETO THE AXLE SHAFT TUBE.DISCARD THE NUTS.REMOVE AXLE SHAFT FROM HOUSING.WITH AN AXLE PULLER ATTACHED TO A SLIDE HAMMER.DISCARD INNER AXLE SEALPOSITION THE AXLE SHAFT IN A VISE.REMOVE THE RETAINING RING BY DRILLING A 1/4 HOLE ABOUT 3/4 OF THE WAY THROUGH THE RING. THEN USING A COLD CHISEL OVER THE HOLE.SPLIT THE RING.REMOVE THE BEARING WITH A ARBOR PRESS DISCARD THE SEAL AND REMOVE THE RETAINER PLATE.TO INSTALL - CLEAN THEN APPLY A THIN COATING OF WHEEL BEARING LUBRICANT TO THE BEARING AND SEAL CONTACT SURFACES APPLY WHEEL BEARING LUBRICANT TO THE LIPS OF THE REPLACEMENT INNER AND OUTER SEALS.INSTALL THE INNER SEAL WITH THE OPEN END OF THE SEAL FACING INWARD ENSURE IT IS COMPLETELY SEATED.INSTALL THE RETAINER PLATE AND THE OUTER SEAL ON THE SHAFT.ENSURE THE OPEN END OF THE SEAL FACES TOWARD THE AXLE SHAFT BEARING.PACK THE REPLACEMENT BEARING WITH WHEEL BEARING LUBRICANT AND POSITION ON THE AXLE SHAFT PRESS INTO PLACE.PRESS A REPLACEMENT BEARING RETAINER ON THE AXLE SHAFT AGAINST THE BEARING.INSTALL THE AXLE INTO THE AXLE TUBE.POSITION AND ALIGN THE SEAL RETAINER AND BRAKE SUPPORT PLATE AND INSTALL REPLACEMENT ATTACHING NUTS.TIGHTEN NUTS TO 32 FT LBS.INSTALL BRAKE ASSEMBLY WHEELS LOWER VECHICLE. YOU SAID REAR BEARINGS IF THIS WHAT YOU MEANT.I HOPE THIS CAN HELP.
Apr 12, 2010 | 1997 Jeep Grand Cherokee
Changing rear axle seal on 78 ford f150. looking for diagram.
You probably have the 9 inch differential. If it is a rear wheel seal remove the tire and wheel assembly. Be sure to use a jack stand so you don't have the vehicle fall on you. Remove the 4 retaining bolts that hold the backing plate onto the housing. Pull the axle from the axle tube. It may be stubborn at removal. If it is the pinion seal remove the drive line. Remove the pinion nut that rests inside the yoke. Try to use an impact tool for easy removal. Once the nut is off the yoke willcome off. You may need a puller to help in removal. One the yoke is off remove the pinion shaft seal. Replace with a new seal. install the yoke and the washer and then the pinion nut. Re-torque the pinion nut to 150 foot pounds.
Jan 17, 2010 | Ford F-150 Cars & Trucks
How to replace thunderbird antenna
please rate service.
Automatic Electric Antenna
Removal
  1. Lower electric antenna (18850) .
  1. Remove rear retaining screws of RH front wheel splash shield for access to antenna lower retaining bolt.
  1. Remove lower retaining bolt.
  1. Remove radio antenna nut (18865) from top of motor tube and remove electric antenna through fender/splash shield access.
  1. Disconnect signal cable and motor wire connector(s).
Installation
  1. To install, reverse Removal procedure.
  1. Tighten top radio antenna nut to 6-8 Nm (54-70 lb-in).
  1. Tighten lower electric antenna retaining bolt to 5.8-7.8 Nm (51-69 lb-in).
  1. Check operation of electric antenna and radio chassis .
mast
Mast, Power NOTE: A power antenna mast which is bent or broken can be replaced without replacing the motor and tube assembly.
Removal
  1. Remove radio antenna nut (18865) and radio antenna stanchion (18919) .
  1. Loosen retaining nut inside tube using 14 mm (9/16 inch) socket, and slide nut part-way up mast.
  1. Raise antenna to run plastic drive wire at bottom of mast out of motor. Note direction of teeth on plastic drive wire.
  1. Saw off damaged portion of antenna mast. Remove burrs from mast and slide nut and contact tube off stationary tube.
Installation
  1. With the teeth on the plastic drive wire facing toward motor on antenna, push end of plastic drive wire of replacement mast assembly down into tube. Push it around curve at bottom of tube until end enters drive mechanism.
  1. Run motor down while pushing on plastic drive wire until about 305 mm (12 inch) of wire has been drawn into the tube. Stop motor and insert bottom of antenna mast into tube. Lower mast.
  1. Slide contact tube and radio antenna nut down antenna mast. Tighten nut to 0.45 Nm (4 lb-in).
  2. Raise and lower antenna several times to ensure proper operation.
Jul 09, 2009 | 1995 Ford Thunderbird
I cannot get the rear wheel off the tractor. Question... the ''square key''... I thought mine was missing & secured another one, but WHAT DO I DO WITH THE SQUARE KEY ? Is the original still in the hub part...
Here is what my manual says. It is for a 14 hp 42" mower deck. 6 sped transaxle.
Block up axle securely.
Remove axle cap, retaining ring and washer to allow wheel removal (rear wheel contains a square key. Do not lose).
Repair the tire and reassemble.
On rear wheels only: align grooves in rear wheel hub and axle. Insert square key.
replace washers and snap retaining ring securely in axle groove.
Replace axle cap.
If you send me your email address I can send you a picture as I do not know how to post pictures on here yet.
Apr 24, 2009 | Craftsman Garden
I need to know how to get to the rear suspension (tower)
i don't think you have to do any repairs from the top end. I will list most fromFord shop manual. Please rate as Fixya if this answers your questions. Please report back. Good luck.
Section 04-02: Suspension and Wheel Hubs, Rear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION Spring Rear
Removal
  1. Position a hoist under the rear axle housing, and raise the vehicle. Refer to Section 00-02 . Place jackstands under frame side rails.
  1. Remove rear stabilizer bar as outlined.
  1. Disconnect the lower studs of the two shock absorbers from the mounting brackets on the rear axle assembly .
  1. Unsnap the RH parking brake rear cable and conduit (2A635) from RH upper arm retainer before lowering the rear axle assembly .
  1. Lower the hoist and axle housing until the rear springs are released.
  1. Remove rear spring and rear spring center mounting insulators (5741) from vehicle.
Shock Absorber Removal
Raise the vehicle on a hoist. 1. To assist in removing the upper attachment on shock absorbers using a plastic dust tube, place an open end wrench on the hex stamped into the dust tube's metal cap. For shock absorbers with a steel dust tube, simply grasp the tube to prevent stud rotation when loosening the retaining nut.
  1. Remove the shock absorber retaining nut, washer, and insulator assembly from the stud on the upper side of the frame. Discard nut. Compress the shock absorber to clear the hole in the frame, and remove the inner insulator and washer from the upper retaining stud.
  2. Remove the self-locking retaining nut, and disconnect the shock absorber lower stud from the mounting bracket on the rear axle tube.
  3. Perform Shock Absorber Checks. Refer to Section 04-00 to determine shock absorbers performance.
Installation
  1. Properly prime the new shock absorber . Refer to Section 04-00 , Shock Absorber Checks.
  1. Place the inner washer and rear spring insulator (5536) on the upper retaining stud, and position the shock absorber so that the upper retaining stud enters the hole in the frame. While holding the shock absorber in this position, install a new rear spring insulator , washer and nut assembly on the upper side of the upper frame. Be sure to seat the rear spring insulator in the frame attaching hole. Tighten nut to 34-46 Nm (25-34 lb-ft).
  1. Extend the shock absorber , and place the lower stud in the mounting bracket hole on the rear axle assembly housing. Install a new self-locking retaining nut. Tighten nut to 76.5-103.5 Nm (56-76 lb-ft).
  1. Lower vehicle.
Arm Lower
Removal
Refer to the illustration in Description and Operation. NOTE: To improve rear axle assembly noise and vibration concerns, the rear suspension should be fastened to the frame and rear axle assembly at the curb height position.
NOTE: If one rear suspension lower arm requires replacement, also replace the opposite rear suspension lower arm .
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN REAR SUSPENSION LEVELER COMPRESSOR SWITCH OFF (IF SO EQUIPPED).
NOTE: If both rear suspension arm and bushings and both rear suspension lower arms are to be removed at the same time, remove both rear springs as outlined under Rear Spring Removal. For air spring removal, refer to Section 04-05 .
  1. Mark rear suspension shock absorber relative to protective sleeve with the vehicle in a static, level ground condition.
  1. Raise the vehicle on a hoist, and place jackstands under the rear axle assembly . Refer to Section 00-02 .
  1. Lower the hoist until the shock absorbers are fully extended to relieve rear spring pressure.
  1. Support rear axle assembly under differential pinion nose as well as under rear axle assembly .
  1. Remove and discard the lower arm pivot bolt and nut from the axle bracket. Then, disengage the rear suspension lower arm from the bracket.
  1. Remove and discard the pivot bolt and nut from the frame bracket, and remove the rear suspension lower arm .
Upper
Removal
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Suspension Bushing Service Set T79P-5638-A1, A2 and A5 Rear Axle Control Arm Bushing Tools T86P-5638-AH
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN OFF REAR SUSPENSION LEVELER COMPRESSOR SWITCH (IF SO EQUIPPED).
  1. Raise the vehicle, and support the frame side rails with jackstands. Refer to Section 00-02 .
  2. Support the rear axle assembly .
  3. Lower the rear axle assembly , and support the rear axle assembly under differential pinion nose as well as under rear axle assembly .
  4. Unsnap parking brake rear cable and conduit from upper arm retainer.
  5. Remove and discard the nut and bolt retaining the rear suspension arm and bushing to the rear axle assembly housing. Disconnect the rear suspension arm and bushing from the housing.
  6. Remove and discard the nut and bolt that secures the rear suspension arm and bushing to the frame bracket, and remove the rear suspension arm and bushing . If upper arm rear bushing is to be replaced, use Suspension Bushing Service Set T79P-5638-A and Rear Axle Control Arm Bushing Tools T86P-5638-AH and the following procedure:
  7. Place the upper arm rear bushing remover tool in position, and pull bushing out. Using Suspension Bushing Service Set T79P-5638-A install bushing assembly into bushing ear of rear axle assembly.
Stabilizer Bar
Removal
  1. Raise vehicle on hoist, and place jackstands under the frame side rails. Refer to Section 00-02 .
  1. Lower the hoist and rear axle assembly housing until the shock absorbers are fully extended.
  1. Disconnect rear stabilizer bars from rear stabilizer bar link and bushing (5C488) . Remove bolts and stabilizer bar bracket (5486) retaining rear stabilizer bar to rear axle assembly .
Mar 05, 2009 | 1994 Lincoln Town Car
How to replace front wheel bearing on 2003 GMC ENVOY
Jack up vehicle and support with jack stands
Take off wheel
remove brake caliper
remove caliper bracket
remove rotor
remove axle retaining nut cotter pin
remove axle from output flange
pull axle out of vehicle
hub and bearing assembly held in by 4 bolts
installation is reverse of removal. You will need to find out the torque specs for the axle retaining nut.
Jan 14, 2009 | 2002 GMC Envoy
Rear axle berrings
Tools needed- typical socket and ratchet set, Axle slide hammer, Wiz Wheel type rotary cut off tool, chisel, ball pein hammer, hydraulic press, bech vice
First you must remove the rear wheels, then you must remove the brake capiler and mounting bracket, remove the brake rotor. unbolt 4 nuts on back side of brake dust shield that hold the seal and bearing securly in place. then you must attatch the slide hammer to the axle shaft by using the vehicles lug studs and lug nuts. use the slide hammer to knock the axle shaft out of the housing. it generally takes about 10-15 hard slams before it comes loose. once axle shaft is free to come out remove the slide hammer and pull the shaft from the axle tube. place the axle shaft into a vise and use the cut off wheel to cut off the bearing spacer. cut parralell to shaft until you hear a snap sound once it snaps use the hammer to slide the spacer off the end of the shaft. next you need to cut the bearing off the shaft using a the same technique being careful not the cut the shaft or the seal retainer plate. once the bearing is off then you can slide off the old axle seal. now slide on a new axle seal, axle bearing, and bearing spacer. take assembly to a hydraulic press and press the spacer and bearing onto the shaft until it seats squarely and make sure its all the way down onto the axle shaft. lubricate bearing with gear oil. and install shaft back into axle tube making sure that the recess in the seal retainer plate lines up with the abs sensor wire. tighten all nuts evenly top off gear oil
Dec 27, 2008 | 1999 Jeep Grand Cherokee
Coleman Roadtrip Grill LXE 9949-750 Logo
910 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
