Question about Bernina Virtuosa 160
Input power We are moving to Singapore and looking at the sewing machine I see it is capable of 100-240V, 50-60Hz., but on the side of the case it shows a decal indicating 110-120V. Is there a user selectable voltage setting on the inside of the machine circuit card?
  • 106 Answers
Yes there will be a selector switch inside the machine, this will be near the motor and is either a rotary or flick switch.
Posted on Mar 30, 2008
How do i move the needle from side to side please
Zig-zag? Set the stitch width to something larger than zero.
Needle Position? If your machine has the capability, there would be a needle position selector--usually for center, left or right. Newer machines would probably have more selections than the three.
Sep 17, 2017 | Sewing Machines
How to raise feed dog?
look in the instruction manual, the information should be in there
Apr 09, 2016 | Sewing Machines
Skipping stitches on bobbin thread Juki DDL555-5. any suggestions?
sounds like u have the wrong needle or machine is out of time. if its a needle feed machine u might have the wrong bobbin case. try lowering the needle slightly. machine is easy to time. theres a mark on the needle bar which u align with the bottom of the bar guide then loosen the hook (3 screws) and move hook till it just starts to meet the needle. careful of side to side movment. bobbin case has to remain in the finger.
Mar 27, 2014 | Juki Sewing Machines
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
Arm wont move and needle wont go up and down any more in the middle of sewing, I was in the middle of sewing and all the sudden it froze up. It wont move any more and when you try you cant hardle move the...
Annoying solution, but works every time. Remove the ENTIRE bobbin casing from the base and then turn the wheel. The needle should lift right out. Reassemble bobbin casing and oil very well.
This generally only happens when you are sewing through several layers of fabric or though a thick fabric. If you are doing neither, the timing in your machine may be off and you will need to get it repaired.
Jul 04, 2010 | Singer 3116 Simple
My brother sewing machine went off because of improper power usage. The machine was purchased in USA,(110-120v) I was trying to use it in India (220-240v) I was using a power converter with low...
Sorry to say, you probably burned up the motor (judging from the burning smell). The solution would be to replace the motor, but that might not be as easy as it sounds, especially if your sewing machine is computerized.
I looked all through Brother's web site for a dealer in Chennai, India, but all I could find was this: Hope it helps!! Robbie
India Facsimiles, Printers,
Multi Function Centers,
Labelling Machines
Domestic Sewing Machines BROTHER INTERNATIONAL (INDIA) PRIVATE LTD.
website: http://www.brother.in Industrial Sewing Machines BROTHER INTERNATIONAL SINGAPORE PTE LTD
website http://www.brother.com.sg
Jan 28, 2010 | Brother Sewing Machines
I have singer sewing machine. The black casing the bobbin fits in is supposed to move when sewing, I know, but this seems to move excessively and does not fit in tight enough so that when sewing, it slips...
The black bobbin case that the bobbin sites in is not supposed to move at all, on the right hand side of the bobbin case you will see two screws, if you slacken them off you can push the guide bar closer to the bobbin case leaving enough thread to pass through the gap.
May 12, 2009 | Singer 132QRFB Mechanical Sewing Machine
Wont change settings
Take out the needle, tighten the needle clamp screw.
Select the zigzag setting plus the largest stitch width, run the machine quite fast for a few seconds. Turn the hand wheel so the needle bar is at it's lowest, turn power off, get hold of the needle bar and move it side to side half a dozen times.
Turn on power, run the machine again as before.
Go through all stitch type settings zigzag/straight etc and run the machine in each setting.
If after all that the problem is not solved I am afraid you need a sewing machine tech to have a look at it.
It would be interesting to know the make of machine and how old it is, plus when it was last serviced.
Best of luck
Rob
Mar 26, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
143 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
