Question about Motorola Mobility RAZR V3
I have a motorola razr v3 that i hear fine out of but others cant hear me
I can hear people fine they just cant hear me
  • kimjredbay Mar 30, 2008
    are theya way i can try to fix it myself
    Genius:
  • 3,422 Answers
You will have to get your cellphone repaired that is the only solution to fix this problem.IF it is under warranty then please get it replaced.
You can try taking the phone apart if you want and clean and reattached the connections to the speaker in the phone.
Good luck,
Please don't forget to rate the solution.
Posted on Mar 30, 2008
  • Priya darshan Mar 31, 2008
    To fix it by urself you will have to take your phone apart.Then clean out the dust on the microphone and fix all the wire connections.
  • 818 Answers
Press the up or down volume
keys to:
• silence an incoming call
alert
• increase or decrease
earpiece volume during a
call
• increase or decrease ringer volume when the home
screen is visible (flip must be open)
Tip: At the lowest volume setting, press the down
volume key once to switch to vibrate alert. Press it
again to switch to silent alert. Press the up volume key
to switch back to vibrate alert, then ring alert.
  • 13,433 Answers
Try reseting the phone to factory settings incase there is a setting witch has turned the microphone off.
If that doesnt solve the problem, then the microphone is most likely damaged.
  • Ekse Mar 30, 2008
    Basicly you could take the phone apart, might void your warranty.
  • 796 Answers
May be there is some problem in the main board..
was the phone bought recently??
  • 316 Answers
SOURCE: auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
maybe while pairing up the new phone you have turned down the volume on the earpiece?
Posted on Nov 30, 2007
rhuzmarhuz
  • 167 Answers
SOURCE: motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Posted on Jan 08, 2008
SOURCE: Motorola Razr V3 suddenly stop working - lost outgoing voices ...
open your phone and theres alittle tiny button all the way up at the top push it in with a needle and see if that works
Posted on Mar 15, 2008
  • 32 Answers
SOURCE: Motorola razr v3 display went out
Either your flex cable is broken or came loose. Is the top left hinge button still intact? Is it loose at the hinge? You will need a Torx 4 screwdriver to take the LCD screen apart to check the flex cable inside.
Posted on Jun 01, 2008
SOURCE: Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Posted on Jun 12, 2008
Motorola Razr in water for about 5 min. dry now
From all indications, everything is functioning fine, just that they can not hear you at the other end.
The problem with your phone is the mouthpiece, the mouthpiece of your phone is bad, that is why they can not hear you at the other end.
All you need to do is change the mouthpiece of your phone and you will see that they can hear you at the other end.
Take care.
Apr 30, 2010 | Motorola Mobility RAZR V3
Motorola v3 razr
Got some Pic on the cam. cant delet them please tell me how. And where to start .
Thank you
mawonthebec
Nov 01, 2008 | Motorola Mobility RAZR V3
"unable to charge" message & person on other end cannot hear me
Go to a skilled mechanic, request him to check the charger, the charging connector, the charging controller IC to solve the problem.
Supriyo DG
Jun 12, 2008 | Motorola Mobility RAZR V3
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola razr cant hear incomming call
that might be a little more work.
try your hands free, to see if you get sound
try someones else battery.
reset the phone to default.
This might help you to narrow the problem, If nothing works. you might haver to open it.
Paulo
May 30, 2008 | Motorola Mobility RAZR V3
I have a problem with my motorola razr no one can hear me
you need to hvae the microphone on the phone check to see if it needs to be replaced.
Mar 30, 2008 | Motorola Mobility RAZR V3
Mar 14, 2008 | Motorola Mobility RAZR V3
Razr v3
you need to replace your microphone...take it to a mobile service center.....and have them replace it.
Feb 25, 2008 | Motorola Mobility RAZR V3
Auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
Nov 28, 2007 | Motorola Mobility RAZR V3
V3
you need to have the ear piece cable in the phone replaced.
Sep 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
113 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
