Question about HP Compaq nx6110 PC Laptop
The laptop will only work on the mains cable - HP Compaq nx6110 PC Laptop
  • 20 Answers
Perform battery health test according to the operating system you are using.
for vista:
1. Click on start or windows logo (pearl) button.
2. Click on HP Help and Support.
3. Click on troubleshooting steps and then Battery.
XP:
Please run the following softpack on your notebook to check the battery health:
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32299.exe
Windows 7:
1. Click Start and select HP Support Assistant .
2. On the HP Support Assistant window, select Troubleshoot , and then select Power, Thermal, and Mechanical .
3. Click Battery Check to examine your battery and display the results of your battery status check.
The current state of the battery (charging or discharging) is displayed.
Then you will be knowing what the exact issue is. If the battery health test fails you can replace it.
Posted on Nov 30, 2010
Not getting power at all
check AC - DC adapter could be faulty
Check surge protection if plugged into a surge protected powerboard
Could have a crook powerboard
May 27, 2015 | Computers & Internet
Why is my laptop screen is blank?
is there a dark display when you expose your laptop's monitor to light ? ... if yes check out contrast and brightness buttons ,,, if didn't work the main problem could with the monitor's inverter or the monitor leds ... must be replaced ... if there is no dark display could one of many :
1- check the rams (try another ram to test )
2- check the monitor's cable which connected to the main board
3- check the cpu
4- if nothing of above worked replace the main board ...
give feed back if you can ,,,
Mar 06, 2012 | HP Computers & Internet
Hi I have a dell inspiron 1545 laptop and when I use battery power the mouse pad works perfectly , but when I plug in to the mains , it sticks , is eratic and does not work properly please help.
May be your Power cable is faulty.
Tip
1- just use another cable and check .
2- Use another power socket, may be earthing will be issue here
Dec 02, 2011 | Dell Inspiron 15 Laptop
Only a few keys work but it was working fine last night - i cant even type in the password to access the desktop
keyboard error maybe cussed by :
1. the data cable was loose --> open the keyboard from the laptop and the data cable from the laptop than clean the data cable wait until dry and plug in again use the duck tape to strengthen the cable data connection in the main board.
2. dirty --> open the keyboard from the laptop open all the key (carefully) than use vacuum cleaner to clean all of the dirt or use blow it with air compressor
3. moist --> open the keyboard from the laptop than dry it on the sun or yo can use hair dryer
May 13, 2011 | Computers & Internet
Can this computer be used in Australia without being damaged?
Most laptop can be used in any country.
Check the laptop's power adapter mains input voltage, it is on a label on the bottom of the adapter.
If the input voltage is 100 to 240 volts then it will work in Australia, you may need an mains adapter to connect to Australian 3 pin mains power point or purchase the mains cable that fits the Australian 3 pin mains power point.
Apr 23, 2011 | Toshiba Computers & Internet
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
Packard Bell Laptop goes flat even when plugged into the mains su
Are you sure that the power adaptor is working? Does it have any light on the adapter box that informs about it's operation?
What usually happens is that the cable going from the adapter to the laptop gets crackled from repetitive bending, either at the plug, or at the box inlet. Inspect if the cable is intact, and if possible, checks if there's a required DC voltage on the plug.
Perhaps you might need a new adapter for your laptop.
Dec 07, 2009 | Computers & Internet
Connection to my Desktop not working.
Try and change the cable from the router to computer with a new one and do the same with the modem and see if connects. Hopefully it's just the cables that are faulty.
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
The power / on-off button is flashing rapidly when I attempt to switch on my x1290, and it is not communicating with my laptop, despite USB cable being connected OK. The printer is unresponsive to pressing...
Panic over!! I unplugged the printer from the mains, took out the USB cable etc, rebooted my Laptop, and plugged the printer back in again... this time, when the power button was pressed, everything worked as normal, and it seems to be staying that way.
Jun 10, 2008 | Office Equipment & Supplies
HP Compaq nx6110 PC Laptop Logo
100 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
