Washer won't pump out water makes a grinding noise when turned on
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machinewasher won't pump out water makes a grinding noise - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Hi there! I have a Frigidaire Gallery GLGH1642FS1 stacked washer/dryer. Its making an awful grinding noise while trying to pump water out...the drum still seems to be turning though...any suggestions? Do I...
The washer is separate from the dryer as far as the systems go. It may be possible that you accidentally unplugged the connectors to the water hot valve when doing your repair.
The pump is probably the problem with the noise you describe. if the washer has a belt under the washer it is common for these pump bushings to go bad and make a grinding sound. There could be something stuck in the pump also.
Jun 25, 2014 | Washing Machines
My washer makes a grinding noise and leaks out the bottom
washer makes a sqeeling noise where fan belt is attatched but only in one direction.could the machine need rebalancing?
Feb 21, 2013 | GE WBSR3140DW Top Load Washer
My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
I had this same problem that cropped up about 6 months after I purchased the ice maker. When it pumped water into the ice tray, the water pump would make a loud grinding noise. I inspected the pump and found that the impeller was in contact with the bottom of the pump housing. I partially disassembled the pump and inserted a small washer I fabricated out of electrical tape to enlarge the gap between the impeller and the bottom of the pump housing. I also took care not to over-tighten the screws when reassembling the pump. The grinding noise went away completely, and it's back to normal operation now. Even if you have no idea what you're doing, like me, it's a 15 minute fix with practically zero materials cost.
I have no idea what caused the problem originally, unless there was a washer that disintegrated over several months' worth of use.
Oct 29, 2012 | Emerson Im90 Portable Ice Maker
Washer won't drain. Makes grinding noise
check your water pump. there maybe something in it. If there is you may have to replace the pump
Nov 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Kenmore 60 series grinds when spin starts
try taking the pump off the motor and see if the grinding noise stops could be something in your pump or a bad pump
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
