Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Bar oil leaking constantly. How do I fix it?
It started about 2 years ago. All the bar oil leaks out when sitting in the case. How do I repair this problem?
My wildthing does it too but if i lay it on its side(bar on ground)it doesnt.I have stored mine this way for years and i dont have that problem.
Posted on Jan 24, 2013
I have a chain saw homelite and the bar leaks oil in my case what do i do
Drain oil back out of tank B 4 you put away , its also a very good idea if you drain and purge gas tank as well , as either of these fluids left in saw will cause u problems if you leave in inside for long periods(< week) when you restart saw
Jun 17, 2014 | Homelite Garden
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
Chain oil leaks out quickly a rancher 55
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Jul 11, 2010 | Husqvarna Chain Saw 20" Bar
Chain not lubricating
Remove the bar and chain. Clean all parts exposed including the bar drive-end small oil channels that feed oil out to the chain groove on both sides of the bar. Start the engine and look for oil oozing out of a small side port where the bar fits to. If ok and no oil seems to coming from under the case, reassemble all components. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw in the case back near the lower run of chain or just under the case in the same area. Turn CW to reduce volume. Hope this helps!
Jul 06, 2010 | Husqvarna Chain Saw 20" Bar
The oil is leaking from the bottom or where the bar & chain is. I'm not sure which one it is. It is a Craftsman 14 inch chain saw.
Remove the bar and chain, then remove the excess oil and debris. Start the engine and look for oil oozing out of a port near where the bar fits to the case. Any spills while filling the oil tank will allow oil to drip from the case. If the oil comes out properly, clean the drive end of the bar, especially the two small passages from the larger holes out to the chain groove on each side. Clean the chain groove all the way around and inspect the tip sprocket condition. Reassemble the bar and chain, then run the engine for short time with the tip near cardboard to see if it will throw off a thin line of oil onto the cardboard. Hope this helps!
May 17, 2010 | Garden
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan-Pro 295 leaks excessive bar-chain oil
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
Jul 18, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Bar chain oil leaking into case when not in use
if you store it somewhere other than a climate controlled building , the changes in temperature can cause the oil to expand out of the saw a little each time the temp. goes up.
try some absorbent cloth
Jun 20, 2009 | Homelite ZR10926 16" Chain Saw
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
179 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
