Question about Microsoft Xbox 360 Console
DVD Drive tray needs new alignment
Can you provide instructions on how to accomplish this?
Thanks.
    Sergeant:
    Champion:
  • 427 Answers
This is the only possible way;
Call 1-800-4MY-XBOX and they might charge you (depending on your warranty status) but they will fix it right the first time, and they are trust worthy.
Posted on Apr 01, 2008
SOURCE:
Insert tray in Phillips cd rewritable drive
If the tray is out of alignment you may as well replace the entire DVD R/W device. Even if you manage to reset the alignment, the read/write head may be misaligned and recording messed up. A new drive is only $30
Jan 05, 2014 | Philips Dh-16a6s 16x Dvdrw/cdrw Rewritable...
The dvd tray wont open up
Is it trying to eject the tray when the OPEN/CLOSE button is pressed? If so, then the tray is probably out of alignment/jammed. If the drive shows no signs of life at all, then it is likely the drive is defective/dead, and will need to be replaced. A new DVD-RAM drive could be expensive, plus the labour costs on top, would make this uneconomical.
I do not recommend that you disassemble the DVD drive (if the tray is stuck) unless you have a schematic 'exploded' diagram of the drive itself (showing each part separately by name and/or number) along with a service manual on alignment procedure. Unless you have experience with these, you risk further damage.
On the other hand, consider ordering a new DVD drive (they start around $130US (cheapest for a new VXY1961 DVD-RAM drive - which suits this model) and upwards plus shipping). Prices may vary depending where you obtain the drive from.
It is easier, quicker, and possibly cheaper to simply replace the drive rather than try to fix the old one. If you do go ahead and order the drive and fit it yourself, you save on workshop labour costs. You do not need to remove the front face panel of the combo unit to replace the DVD drive.
The good news is at this stage you will NOT need to replace the entire combo unit; if you do visit a repair centre, get a quote on the costs involved, and a second opinion - particularly about your DVD drive. You can also ask them whether a new disc drive is required, and where to obtain a new one from. They may be able to assist you further. The purpose of the second opinion by a workshop is to enable you to make a concise decision as to whether to simply replace the drive yourself or accept their quote for service. Up to you.
I hope there are no other faults within this unit.
Apr 07, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Is there an instruction manual that tells you how to install and get started?
It depends on what you are trying to install I'm assuming the Operating System. The question is not complete. More info is needed please repost with what you are trying to install, thanks for using Fixya! John
Mar 01, 2011 | Computers & Internet
Dvd writer's flap not going in..
Breaking of cd indicates that the cd is not aligned (tightened) properly between the spindle and the magnetic top, if the tray dos'nt align properly it may not lift the spindle up, open the drive and check for any obstacles in the tray path, important if your drive uses rubber belt to drive the tray in-out replace the belt, also check the magnetic top for breakage.
Jul 24, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
I need to burn dvd with phptos and vidio on the one disk
  • Click on "Start" in the lower left-hand corner of the desktop screen. Then select "All Programs," "Accessories" and "Windows Explorer."
  • Open the DVD burner tray and insert a blank DVD or CD. Close the tray.
  • Navigate to the hard drive that has the files to be burned. Click on the files or folder to be burned, and drag to the DVD burner drive icon in Windows Explorer.
  • Select "File," then "Write these files to CD." Ensure that all the files that need to be written to the CD or DVD are on the list in the temporary files area that can be found in Windows. The CD writing wizard will open; follow the instructions in the wizard.
  • Remove the CD or DVD when finished and apply label. Close drive tray.
Thanks, SF
Jan 28, 2010 | Microsoft Windows XP Professional
Xbox 360
Your tray needs new alignment. Try opening up the CD Drive and disassemble it up to the tray. Take the tray out and re-align it. Try looking for tutorials on how to fix the DVD drives. I can't really explain that well about how to re-align the tray of the CD Drive.
Dec 21, 2007 | Microsoft Xbox 360 Console
Xbox trouble
Your CD Drive tray needs new alignment. I don't know what to say about your Video Port since it works sometimes.
DVD Drive Tray Alignment -
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Dec 20, 2007 | Microsoft Xbox Console
Broken
there is a switch located inside of the console that tells it when the tray is closed or when it is open it has broken off the best thing to do is send it to microsoft sorry to be the bearer of bad news
Dec 11, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
573 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
