Question about Maytag Ensignia MAV2757AWW Top Load Washer
Tub is filling with water while off. Is it the control valve inside the washing mach?
  • Maytag Master
  • 43,501 Answers
My washer won't stop filling water
Either the small plastic tube that goes from the tub to the fill valve switch is loose or broken, or the water fill valve is jammed due to mechanical failure or a chunk of debris got by the inlet screen and is jammed in the valve. Neither of these is a big deal to fix if you are mechanically inclined. Checking the tube involves looking inside the machine from the control panel to the tub. A fill valve is about equal in difficulty to repair as replacing a circuit breaker in a home electric service panel.
Good luck.
Mar 01, 2011 | GE Washing Machines
Water keeps filling in tub
there is a tube that goes from the side of the tub to the water height valve inside the control panel. make sure it is still attached, has no holes in it. blow through the tub side of the hose and, listen for a soft click from the valve; no click replace the valve.
Aug 09, 2010 | Kenmore 24032\24036 Top Load Washer
The water will fill the tub, agitation will begin,
Yes, you have it figured out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
May 05, 2010 | Washing Machines
Washing maching overflows
inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
May 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Tub is filling with water while off. is it the control valve inside the washing mach?
You need to check your water level switch. Make sure the clear hose that runs from the tub to the control panel is clear, not kinked or clogged and has not come loose at either end. Hope this helps
Mar 21, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
The water level switch senses the water level in the wash tub. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch. Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If the Tube is full of any water, remove it from the switch and replace it with a new one. Make sure that the new is correctly fitted to the switch.
The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle. If the tube replacement dose not improve the fill performance, and it continues to overfill, replace the timer.
Aug 04, 2009 | Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Ensignia MAV2757AWW Top Load Washer Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
