Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
Canon MF4370dn 4-in-1: scaner software installation problem
I just bought a Canon 4370dn network 4-in-1 printer. The probelm I have is the scaner driver installation. Once I installed the driver - Color Network scangear only scangear Tool is installed the main application software (color Network Scangear) was not installed at all. I went online dowwnloaded the latest driver 261 and installed it Tehn exactly the same thing happened. I am using Windows xp home edition with Service pack 3. Anybody can help on this? Thanks.
Read the manual instruction.and call canon service center and get assistance from tech support.
Posted on Jan 14, 2011
2 Suggested Answers
muntejaya
  • 10421 Answers
SOURCE: Canon MF4370dn 4-in-1: scaner software installation problem
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay chvgt
Posted on Feb 12, 2011
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
How do I add a printer to the network?
How to create an IP address into your Printer
1, Connect to LAN network
2, Power ON the Printer.
3, Select MENU Button
4, Go to System Settings, then select Network Settings.
5, You can see TCP/IP , View IP ,etc.....
6, Type Your Printer IP address, Subnet Mask, GateWay, etc...
7, That's All......
In different Printer settings will be different.
Now You can add printer into your computer
Go to Control Panel--> Hardware and Sound -->Device and printers -->Add Printer-->Add network Printer-->"If no printer were found" Select "The printer that i want isn't listed" --> Add printer using TCP/IP--> Type your Printer IP address--> Now you can install printer software...
Thanks
Oct 10, 2012 | Canon imageCLASS MF4370dn...
How to change cartridge for canon MF4370dn printer
I am trying to change the time on the Cannon MR 4370dn...any ideas?
Sep 14, 2010 | Office Equipment & Supplies
Vista says CANON MF4370dn printer always offline? IP addrs issue?
first of all, download updated driver from software.canon-europe.com and install ( before install, remove old drivers and programs)
and if appears again, change your network cable.
Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
In Win Vista my new Canon mf4370dn is being reported as offline.
Go to this canon site and install the firmware update. This was happening to me all the time until I installed this firmware update and now I can print to it all the time. I used to have to turn the printer off and back on just to get the printer to wake up.
http://canoncanada.custhelp.com/app/answers/detail/a_id/20228/~/imageclass-mf4370dn-firmware-update
Jan 13, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Purchased Canon 4370dn and provided scanner software is ****
Free capture is a screen capture software. If you want to import scans then just use paint and save as a jpeg.
Aug 25, 2009 | Canon i-SENSYS MF4140 All-In-One Laser...
When I purchased my Canon 4370dn I was u7nder the
Actually, Omnipage should be included on the CD that came with the unit. If (and I mean if) scangear installs correctly AND locates your 4370dn on the network, it will install itself as a shim TWAIN driver. After the installation of Omnipage, you will need to do a scanner setup and identify the scangear shim as the scanner you intend to work with. After that, Omnipage should work just fine using your 4370dn on the network.
Word of warning: I've had a lot of trouble with scangear if it doesn't install correctly or locate your device on the network. For whatever reason, sometimes it just doesn't want to cooperate sometimes and seemingly nothing you do will convice it that your device is alive and well on the network (including continous ping to the device and/or opening the web interface while installing). This is particularly true for Win64.
Mar 04, 2009 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
877 people viewed this question
old marine
old marine
