Wash motor timer not working. Would like to buy a new timer. Kindly tell where available in delhiindia. Make of timer is Ningbo Donghai Timer Company Limited Type : DXT-35SF-104.
  • 343 Answers
Best to contact the manufacturer of the washing machine, or the service agent. They would have access to a new or perhaps reconditioned part....Good luck....Nomess
Posted on May 16, 2010
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
Can you show me paragon timer 4003-0 the wiring
1) Copy following links:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://waterheatertimer.org/images/Paragon-4000-series-wiring.jpg
2) 4003-0 is 120Volt timer so clock voltage is 120V
Timer can control 120V or 240V loads
Use diagram 3
3) Paragon is no longer making this timer or parts for timer.
If you purchased timer from ebay, then assume motor is bad or X2772 trippers are worn out.
Always buy new timers. Buy Intermatic and parts are easily available.
4) Replacement timer is Intermatic T101
Feb 16, 2013 | Paragon Hardware & Accessories
How can I tell if my t101 motor is not working
Connect 120Volts to white clock motor leads.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Blow out timer with compressed air.
Turn off power and spray highly flammable vapor from WD40 can onto gears.
If dial rotates and keeps good time, then buy new 156T1978A trippers
T101 timer comes stock with WG1570 120-480 volt clock motor.
Clock motor typically connects to terminals A and 1.
Hot black wire connects to terminal 1. Neutral white connects to terminal A.
Load wires: Black to terminal 2, and White to terminal A
This timer can be converted to other voltages by changing clock motor, such as 208-277Volt using WG1573. Or adapted to European, SE Asian 230 Volt 50Hz timer by installing WH1574.
Nov 28, 2012 | Intermatic T101R3 110 volt time clock in a...
TIMER HAS STOPPED ROTATING, DO I NEED A NEW TIMER UNIT OR CAN THIS BE REPAIRED. SHOULD I USE WD40. PLEASE EMAIL susan.labi@hotmail.co.uk THANK YOU
1) It depends on timer you have.
Intermatic-brand box timers used to control water heaters, outdoor signs, pool pumps and parking lot lights generally have replaceable clock motor.
paragon-brand clock motors are not available.
Tork-brand clock motors are more difficult to find, depending on model number.
In-wall timers & plug-in timers are not repairable, and you buy a new timer.
2) Add a comment and describe your timer.
3) ook on following links to help identify timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Compare-timers.html
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Water Heaters
My automatic timer is not working.
You posted under Intermatic raintight timer.
Add a comment with your model and brand and I have extensive files on timers.
The best diagnostic is the manual override.
1) Click manual override and see if Load (lights, fan, motor) come on.
If manual override clicks on-and-off crisp and clean, but the lights do not come on, check your electric power.
If the manual override does not click crisp and clean, then the timer may be rusty, or timer may need to be replaced. Buy replacement timer and swap out timer mechanisms without changing the box.
If the manual override works fine, and Load turns on-and-off with manual override, then the clock or trippers are next suspect.
2) Check if the dial is turning as time passes.
If the dial is not turning, then the clock motor is bad and you can buy a new clock motor.
If dial is turning, and manual override turns Load on-and-off, then the tripper pins might be worn out, and you can buy new trippers.
3) To buy replacement parts: Timer door has model number of timer. Timer clock located on back of timer mechanism has identifying numbers. You can snap out the timer mechanism using metal spring locate top inside box.
Grainger sells trippers and motors:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Aplus sells motors:
http://www.aplussupply.com/intermatic/timermotors.htm
Intermatic sells motors:
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Nov 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
The Cycle selector Knob of 417.42052100 is not moving itself. Machine stays in the washing action without moving automatically to the next one
The timer motor is bad. I am assuming that you can move the timer by hand and access all cycles. Usually this means a whole new timer. You can try to order the motor seperately but it is usually not available alone. The new timer can cost around $100. Why don't you try a used appliance store and see if they will sell you one. The timer motor is fairly standard. The timer itself is not. Just buy a used timer and swap motors.
Jul 05, 2008 | Kenmore Washing Machines
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
