Question about Cell Phones
DISMANTLING SAMSUNG D840
Hi, i am trying to dismantle a samsung D840 TO REPLACE FLEX/RIBBON HAVE TAKEN 4 SCREWS OUT, AND 1 IN AMONGST THE COMPONENTS,BUT DONT SEE ANY MORE SCREWS I CAN TAKE OFF TO
GET ACCESS TO FLEX RIBBON,DONT WANT TO FORCE ANYTHING
  • 21 Answers
You have acted correctly up to this point.Now free the button pads on both sides from were they are stuck down they are attached to the main board so be gentle you only need to move them off the plastic boards they are fixed to.Now remove the grey square of tape in the battery compartment and unplug the little black wire from the main board it just lifts off. now lift up the main board from the battery compartment end and as you lift it a plug in flex will detach itself turn the main board up at an angle and you will see the flex attachment underneath.Take the green plastic off and flick the hinge to remove the flex,it is soldered on both sides like a lot of samsungs but if your replacing the flex just tear it and work on it when the board is removed.This next part is where you can go realy wrong ignore all the screws that you can see open the slide of the phone and remove the covers that conceal the 2 screws at the top of the phone remove them now with the slide fully open you will see 2 holes at the bottom of either side of the slide look in and you will see 2 screws that hold the bottom of the screen cover remove them.now the slide section will easily be removed from the screen section you may have to operate the slide slightly to allow the flex to exit then you have easy access to the flex on the screen attachment .Rebuild in reverse taking note on how the flex is bent as its crucial to the slide operating smoothly
Posted on Dec 06, 2009
SOURCE:
When I take pictures with my Samsung L201 there are horizontal lines on the picture when I look at them on the camera or computer
Greetings.
To resolve this problem you need to replace the ribbon cable inside the lens shutter.
For the unprepared person, unfamiliar with the repair of cameras - a difficult task. Such work can perform any repair.
For self-repair is necessary:
1 soldering iron, solder, flux
2 Tweezers
3 Screwdriver, small
4 Device for capacitor discharge flash
5 optics for if poor eyesight
Skills:
1 Reading the manual repair
2 The ability to solder
3 understanding of the mechanics of the lens (you must correctly parse and then properly assemble the mechanical part of the lens)
Flex -
Flex Samsung shutter L201 digital camera
Manual -
Samsung Digimax L201
Oct 03, 2014 | Samsung L200 Digital Camera
SGH D840 Screen Blank out and No Sound
did you try removing batteries and putting them back
Jul 28, 2008 | Samsung SGH-D840 Smartphone
My n73 back camera not working in new body
this is normally a flex/ribbon problem. theese nokias suffer from this. it will require dismantling the handset. it may just be a loose connection or it may need a new ribbon. good news is they are not expensive to buy.
May 03, 2010 | Nokia N73 Cellular Phone
Buttons on the slide of j700 donot work while opening slide
hello,
the problem seem to be from the flex that connects the keypad to the screen. it is repairable, first you flash the phone to see if it would work then if it doesnt then you replace the slide of the phone then it would work perfectly. the process is complicated so i'll advice you take it to an expert and if you insist on fixing it yourself.
then you'll have to get a complete set of screw driver, and a replacement flex, then you'll carefully unscrew the phone, then you locate the flex after carefully dismantling both sides of the phone then you replace the flex and recouple it back carefully. the try to turn it on and test the keys.
Jan 31, 2010 | Cell Phones
Replace CMOS battery
The CMOS battery is on your motherboard. It looks like a small watch battery. As for as dismantling it there are no directions on the Samsung website. Best thing to do is check You Tube on how to dismantle a laptop or by Scott Mueller's book on Amazon.com how to troubleshoot and repair laptops. There is not enough room on this website to go thru each step. Basically you turn it over and start taking out all the screws and panels until you get to the motherboard.
Rate this solution with 4 stars before logging out.
Mar 15, 2009 | Computers & Internet
DISMANTLING MY PHONE
how do i dismantle U700 ? can any body help ???
Sep 10, 2008 | Samsung SGH-U600
Camera malfunctioning
sorry for the long response it is the camera that need to be replaced
Mar 18, 2008 | Samsung D840 Cellular Phone
Samsung d600
you will need a professional to look at it. try a local center if it doesnt work we at http://horizonwirelessonline.com can do it no problem (if you have the parts) about $25 + shipping
Dec 11, 2007 | Samsung SGH-E630 Cellular Phone
D500
faulty flat cable that connects lower and upper part of the phone...
Aug 26, 2007 | Samsung SGH-D500 Cellular Phone
Cell Phones Logo
523 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
